Ir para o conteúdo principal
Shark ION Robot R75 Caster Wheel Replacement
O que você precisa
    1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: passo 1, imagem 1 %32
      • Orient the device with the bottom facing up.
      Pergunte ao FixBot
      Comentar
    2. Shark ION Robot R75 Caster Wheel Replacement: passo 2, imagem 1 %32 Shark ION Robot R75 Caster Wheel Replacement: passo 2, imagem 2 %32 Shark ION Robot R75 Caster Wheel Replacement: passo 2, imagem 3 %32
      • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
      • Remove the wheel.
      Pergunte ao FixBot
      Comentar
    3. Shark ION Robot R75 Caster Wheel Replacement: passo 3, imagem 1 %32 Shark ION Robot R75 Caster Wheel Replacement: passo 3, imagem 2 %32 Shark ION Robot R75 Caster Wheel Replacement: passo 3, imagem 3 %32
      • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
      • Pull the caster assembly up from its slot in the device.
      Pergunte ao FixBot
      Comentar
Conclusão
1Comentário do guia
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 56
Ao todo: 6,169
