Ir para o conteúdo principal
Shark ION RV754 Battery Replacement
O que você precisa
  1. Shark ION RV754 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place the unit on its back with the wheels facing up.
    • Use a Phillips #1 screwdriver to remove the single screw securing the battery compartment door.
    • Use your finger to lift off the battery door using the small indent next to it.
    Pergunte ao FixBot
    Comentar
  2. Shark ION RV754 Battery Replacement: passo 2, imagem 1 %32 Shark ION RV754 Battery Replacement: passo 2, imagem 2 %32 Shark ION RV754 Battery Replacement: passo 2, imagem 3 %32
    • Lift the battery out just above the compartment to access the battery connector.
    • Squeeze the tab against the connector and pull it straight up to disconnect it.
    • Remove the battery completely.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 35
Ao todo: 279
