Ir para o conteúdo principal
Shark Flex DuoClean Suction Motor Replacement
O que você precisa
  1. Shark Flex DuoClean Suction Motor Replacement, Dust Cup: passo 1, imagem 1 %32 Shark Flex DuoClean Suction Motor Replacement, Dust Cup: passo 1, imagem 2 %32
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Suction Motor Replacement, Suction Motor: passo 2, imagem 1 %32
    • Remove the five 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  3. Shark Flex DuoClean Suction Motor Replacement: passo 3, imagem 1 %32
    • Use the iFixit opening tool to remove the top component.
  4. Shark Flex DuoClean Suction Motor Replacement: passo 4, imagem 1 %32
    • Remove the two 15mm screws by twisting counterclockwise using the T10 Torx screwdriver.
  5. Shark Flex DuoClean Suction Motor Replacement: passo 5, imagem 1 %32
    • Remove the two 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  6. Shark Flex DuoClean Suction Motor Replacement: passo 6, imagem 1 %32
    • Remove the two 15 mm screws holding the motor cover by twisting counterclockwise with a T10 Torx screwdriver.
  7. Shark Flex DuoClean Suction Motor Replacement: passo 7, imagem 1 %32
    • Cut the zip ties holding the motor using the wire cutter.
  8. Shark Flex DuoClean Suction Motor Replacement: passo 8, imagem 1 %32
    • Cut the wires using the wire cutters to completely remove the motor.
    • For reassembly, use the soldering guide in the Introduction.
Conclusão
Christian Fuller
Membro desde: 10/08/18
420 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S17-G5, White Fall 2018 Membro de Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Membros
Autoria de 14 guias
Um comentário
how i need to know how to re connect the wires on replacing a new motor, my model is similar HV321.
andrea - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 21
Ao todo: 3,730
