Ir para o conteúdo principal
Shark Flex DuoClean Power Cord Replacement
O que você precisa
  1. Shark Flex DuoClean Power Cord Replacement, Dust Cup: passo 1, imagem 1 %32 Shark Flex DuoClean Power Cord Replacement, Dust Cup: passo 1, imagem 2 %32
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Power Cord Replacement, Power Cord: passo 2, imagem 1 %32 Shark Flex DuoClean Power Cord Replacement, Power Cord: passo 2, imagem 2 %32
    • Remove the pre-motor filter with your hands.
  3. Shark Flex DuoClean Power Cord Replacement: passo 3, imagem 1 %32
    • Remove the post-motor filter.
  4. Shark Flex DuoClean Power Cord Replacement: passo 4, imagem 1 %32
    • Remove the two 15 mm screws by twisting counterclockwise with the T10 Torx screwdriver.
  5. Shark Flex DuoClean Power Cord Replacement: passo 5, imagem 1 %32 Shark Flex DuoClean Power Cord Replacement: passo 5, imagem 2 %32
    • Remove the two 12 mm screws by twisting counterclockwise with the T15 Torx screwdriver.
    • To fully remove the power cord, cut the wires using a wire cutter.
    • For reassembly, use the soldering guide in the Introduction.
Conclusão
caoimhe
Membro desde: 10/08/18
979 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S17-G5, White Fall 2018 Membro de Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Membros
Autoria de 14 guias
Um comentário
I found with further dissasembly, uncrimping and recrimping the wiring loom saved having to add more connections.
qwazew - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 21
Ao todo: 1,545
