Ir para o conteúdo principal
Shark Flex DuoClean Motherboard Replacement
O que você precisa
  1. Shark Flex DuoClean Motherboard Replacement, Garage Door: passo 1, imagem 1 %32 Shark Flex DuoClean Motherboard Replacement, Garage Door: passo 1, imagem 2 %32
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Motherboard Replacement, Side Component: passo 2, imagem 1 %32 Shark Flex DuoClean Motherboard Replacement, Side Component: passo 2, imagem 2 %32
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Motherboard Replacement: passo 3, imagem 1 %32 Shark Flex DuoClean Motherboard Replacement: passo 3, imagem 2 %32
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Motherboard Replacement: passo 4, imagem 1 %32
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Motherboard Replacement, Top Component: passo 6, imagem 1 %32
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
  7. Shark Flex DuoClean Motherboard Replacement: passo 7, imagem 1 %32 Shark Flex DuoClean Motherboard Replacement: passo 7, imagem 2 %32
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
  8. Shark Flex DuoClean Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Remove one 15mm T10 screw from the inside left of the base of the vacuum to access the motherboard.
  9. Shark Flex DuoClean Motherboard Replacement: passo 9, imagem 1 %32
    • Using the nylon spudger, place the curved side under the motherboard.
    • Gently pry the motherboard out of the base of the vacuum.
    • Do not use your fingers to take out the motherboard, as the bottom can be sharp.
    • The motherboard will still be connected to the base with wires.
  10. Shark Flex DuoClean Motherboard Replacement: passo 10, imagem 1 %32
    • Desolder the motherboard wires using wire cutters.
Conclusão
Equipe
Cal Poly, Team S17-G5, White Fall 2018 Membro de Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 1,507
