Ir para o conteúdo principal
Shark DuoClean Powered Lift-Away Speed Motor Replacement
O que você precisa
  1. Shark DuoClean Powered Lift-Away Speed Motor Replacement, External Pieces: passo 1, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement, External Pieces: passo 1, imagem 2 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement, External Pieces: passo 1, imagem 3 %32
    • Press the Hose Release button and pull back to detach the hose.
  2. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 2, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 2, imagem 2 %32
    • Press the Wand Release button and pull up on the metal tube to remove the entire hose.
  3. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 3, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 3, imagem 2 %32
    • Press the Lift Away button and pull up on the handle to separate the top of the vacuum from the bottom.
  4. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 4, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 4, imagem 2 %32
    • Pull up on the extra brush pieces to remove them from the vacuum.
  5. Shark DuoClean Powered Lift-Away Speed Motor Replacement, Filter: passo 5, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement, Filter: passo 5, imagem 2 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement, Filter: passo 5, imagem 3 %32
    • Pull up on the Dustbin Release button, and pull up on the handle to detach the dustbin.
  6. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 6, imagem 1 %32
    • Pull up on the filter tab to remove the large foam filter.
  7. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 7, imagem 1 %32
    • Pull up on the small tab to remove the filter pad.
  8. Shark DuoClean Powered Lift-Away Speed Motor Replacement, Motor: passo 8, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement, Motor: passo 8, imagem 2 %32
    • Use the T20 screwdriver to remove the two 12 mm screws by turning counterclockwise.
    • Use the T20 screwdriver to remove the two 17 mm screws by turning counterclockwise.
    • Use the T20 screwdriver to remove the two 14 mm screws by turning counterclockwise.
  9. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 9, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 9, imagem 2 %32
    • Use the T20 screwdriver to remove the three 15 mm screws by turning counterclockwise.
    • Use the T10 screwdriver to remove the one 17 mm screw by turning counterclockwise.
  10. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 10, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 10, imagem 2 %32
    • Use the T20 Screwdriver to remove the four 14 mm screws from the bottom of the vacuum by turning counterclockwise.
    • The grey plastic cylinders will detach.
  11. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 11, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 11, imagem 2 %32
    • Use the metal spudger to pry off the back panel.
    • Be careful not to break or snap any plastic.
  12. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 12, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 12, imagem 2 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 12, imagem 3 %32
    • Use the T20 screwdriver to remove the six 12 mm screws by turning counter clockwise.
    • Lift the plastic filter holder upward to detach it from the vacuum.
  13. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 13, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 13, imagem 2 %32
    • Use the T20 screwdriver to remove the one 14 mm screw from the bottom by turning counter clockwise.
    • For reassembly, this screw is difficult to put back in. It is supposed to be very tight.
  14. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 14, imagem 1 %32 Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 14, imagem 2 %32
    • Pull up and back in a twisting motion to remove the motor from its casing.
    • The wire connected to the motor may make it difficult to remove. It may require a lot of wiggling to get the motor out.
  15. Shark DuoClean Powered Lift-Away Speed Motor Replacement: passo 15, imagem 1 %32
    • Use wire cutters to cut the black and white wires coming from the back of the motor.
    • For reassembly, you must strip and then rewire the new motor using wire strippers and end caps. Use this guide to learn more about stripping wires.
Conclusão
To reassemble your device, you must rewire to a new motor, then follow these instructions in reverse order.
5 outras pessoas executaram este guia.
Catie Halvorsen
Membro desde: 10/08/18
703 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S17-G4, White Fall 2018 Membro de Cal Poly, Team S17-G4, White Fall 2018
CPSU-WHITE-F18S17G4
Membros da 4
Autoria de 16 guias
5 comentários
In step 11 there are two additional torx screws to remove, under the finish caps near power and lift away buttons
Phil Blades - Responder
Great Steps . Its Looks More Interested If You can Shoot In Video.
however recently i order a dustbin cleaner with discount which i got from Couponswindow
haydond2 - Responder
I just replaced the motor in a Shark AZ1000W which is similar to this except for the screws in different locations. In step 11, similar to what Phil’s comment says above, there is a screw underneath the dust cup release button. You have to pry that button off. To get that top piece off there are two additional screws on top and one on the bottom. Also in the AZ1000W there is a gray trim piece that goes around the HEPA filter and wraps around the back of the unit. You have to remove that before proceeding to step 14. The trim has two halves you have to separate at the seams where they come together. There are tabs holding it together and it’s hard to separate the halves without breaking the plastic holding it together.
chrisfarmer45 - Responder
My NV752 looks almost just like this until step 13 and 14. It seems like the screw in step 13 doesn't exist, and like there's no way to access the motor. The pinwheel fan-looking part that they pull back in step 14 is fixed to the vacuum, it's the same piece of plastic as the base. I don't think there's any way to get into the motor for NV752 : (
Beth - Responder
Have replaced the motor in my NV680. It all came apart quite easily, but now can't get the back to lower completely. I can't see what is stopping it - it seems the problem leans towards the cable side, but they both don't seem to be the cause. Any ideas anyone?
Edward Shaw - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 69
Últimos 30 dias: 306
Duração total: 29,694
