Ir para o conteúdo principal
Shark Cordless Pet Perfect Front Motor Replacement
O que você precisa
    1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: passo 1, imagem 1 %32 Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: passo 1, imagem 2 %32
      • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
      Pergunte ao FixBot
      Comentar
    2. Shark Cordless Pet Perfect Front Motor  Replacement: passo 2, imagem 1 %32 Shark Cordless Pet Perfect Front Motor  Replacement: passo 2, imagem 2 %32 Shark Cordless Pet Perfect Front Motor  Replacement: passo 2, imagem 3 %32
      • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
      Pergunte ao FixBot
      Comentar
    3. Shark Cordless Pet Perfect Front Motor  Replacement: passo 3, imagem 1 %32 Shark Cordless Pet Perfect Front Motor  Replacement: passo 3, imagem 2 %32 Shark Cordless Pet Perfect Front Motor  Replacement: passo 3, imagem 3 %32
      • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
      Pergunte ao FixBot
      Comentar
    4. Shark Cordless Pet Perfect Front Motor  Replacement: passo 4, imagem 1 %32 Shark Cordless Pet Perfect Front Motor  Replacement: passo 4, imagem 2 %32
      • Remove the belt from the motor mount, and then replace with a new belt.
      Pergunte ao FixBot
      Comentar
    1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: passo 5, imagem 1 %32 Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: passo 5, imagem 2 %32
      • Remove the solder from both motor terminals.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 16-2, Blackwell Spring 2017 Membro de USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Membros
Autoria de 17 guias
2Comentários do guia
Well done, Ashley! You might want to note that using a solder remover is helpful.
Jimbo - Responder Compartilhar
Where can I obtain the new motor with the plastic gear?
F V - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 3,156
