Introdução
This is the Shark AI Ultra AV2511AE guide for the replacement of the drive wheel motors. The motors ensure the movement of this robot's vacuum main wheels. The motor must be replaced if the robot vacuum is not moving or is pivoting to one side.
O que você precisa
Put the device with the wheel side up.
Remove the five 11 mm screws surrounding the drive wheel using a Torx TR15 screwdriver.
Gently pull the wheel assembly out.
Quase terminado!
Conclusão
