Ir para o conteúdo principal
Seville Classics MSC10166 Buttons Replacement
O que você precisa
  1. Seville Classics MSC10166 Buttons Replacement, PCB (Printed Circuit Board): passo 1, imagem 1 %32
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
    Pergunte ao FixBot
    Comentar
  2. Seville Classics MSC10166 Buttons Replacement: passo 2, imagem 1 %32
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
    Pergunte ao FixBot
    Comentar
  3. Seville Classics MSC10166 Buttons Replacement: passo 3, imagem 1 %32
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
    Pergunte ao FixBot
    Comentar
  4. Seville Classics MSC10166 Buttons Replacement: passo 4, imagem 1 %32
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
    Pergunte ao FixBot
    Comentar
  5. Seville Classics MSC10166 Buttons Replacement: passo 5, imagem 1 %32 Seville Classics MSC10166 Buttons Replacement: passo 5, imagem 2 %32
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
    Pergunte ao FixBot
    Comentar
  6. Seville Classics MSC10166 Buttons Replacement, Buttons: passo 6, imagem 1 %32
    • Remove the two 8 mm screws that attach the buttons to the top cover of the fan.
    Pergunte ao FixBot
    Comentar
  7. Seville Classics MSC10166 Buttons Replacement: passo 7, imagem 1 %32
    • Remove the buttons from the top cover.
    Pergunte ao FixBot
    Comentar
  8. Seville Classics MSC10166 Buttons Replacement: passo 8, imagem 1 %32
    • Wipe down any dirt on the buttons.
    Pergunte ao FixBot
    Comentar
  9. Seville Classics MSC10166 Buttons Replacement: passo 9, imagem 1 %32
    • Wipe down the frame that holds the buttons.
    Pergunte ao FixBot
    Comentar
Conclusão
Queena Phung
Membro desde: 09/26/12
114 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 15-46, Forte Fall 2012 Membro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Membros
Autoria de 6 guias
2Comentários do guia
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - Responder Compartilhar
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
Vish Talreja - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 60
Ao todo: 4,717
