Ir para o conteúdo principal
Set-Top Box Numb Button Replacement
O que você precisa
  1. Set-Top Box Numb Button Replacement, Numb Button: passo 1, imagem 1 %32 Set-Top Box Numb Button Replacement, Numb Button: passo 1, imagem 2 %32 Set-Top Box Numb Button Replacement, Numb Button: passo 1, imagem 3 %32
    • Make sure the box is not plugged in before starting!
    • Remove the 5 screws holding the outer casing in place: 3 can be found on the back and 1 on either side of the box.
    • Slide the casing backwards.
  2. Set-Top Box Numb Button Replacement: passo 2, imagem 1 %32 Set-Top Box Numb Button Replacement: passo 2, imagem 2 %32 Set-Top Box Numb Button Replacement: passo 2, imagem 3 %32
    • Disconnect the front of the by lifting the 2 connectors . You can also apply extra pressure on the front from below.
    • Tilt the front forward and remove it.
    • Remove the connector by pressing the upper part of it and carefully pulling it.
    • Be carefull not to damage the cables and circuit board!
  3. Set-Top Box Numb Button Replacement: passo 3, imagem 1 %32 Set-Top Box Numb Button Replacement: passo 3, imagem 2 %32 Set-Top Box Numb Button Replacement: passo 3, imagem 3 %32
    • Undo the 4 screws of the front panel.
    • Locate your broken button. For instance, the third button from the left (front view), is the CH- button.
  4. Set-Top Box Numb Button Replacement: passo 4, imagem 1 %32 Set-Top Box Numb Button Replacement: passo 4, imagem 2 %32 Set-Top Box Numb Button Replacement: passo 4, imagem 3 %32
    • Unsolder the push button. You can push it out or maybe use some plyers.
    • Remove the old button and insert the new one.
    • Solder the new push button on.
    • Check this link for help Como soldar e dessoldar contatos
Conclusão
Yvo Kipping
Membro desde: 12/05/16
101 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 503
