Ir para o conteúdo principal
Service Panel Disassembly
O que você precisa
    1. Service Panel Disassembly, Remove Service Panel Screws: passo 1, imagem 1 %32
      Ferramenta utilizada neste passo:
      Anti-Static Wrist Strap
      $7.95
      • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
      • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
      Pergunte ao FixBot
      Comentar
    2. Service Panel Disassembly, Dislodge Service Panel: passo 2, imagem 1 %32 Service Panel Disassembly, Dislodge Service Panel: passo 2, imagem 2 %32 Service Panel Disassembly, Dislodge Service Panel: passo 2, imagem 3 %32
      • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
      • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
      Pergunte ao FixBot
      Comentar
Conclusão
iodyne
Membro desde: 01/01/22
462 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 24
Ao todo: 428
