Ir para o conteúdo principal
Sennheiser RS120 Battery Replacement
O que você precisa
  1. Sennheiser RS120 Battery Replacement, Ear Pad: passo 1, imagem 1 %32 Sennheiser RS120 Battery Replacement, Ear Pad: passo 1, imagem 2 %32 Sennheiser RS120 Battery Replacement, Ear Pad: passo 1, imagem 3 %32
    • Grip the ear pad with one hand and steady the headset on the other.
    • Twist the ear pad counterclockwise, then lift the ear pad off after about an eighth of an inch of the turn.
    • Replace the old ear pad with a new ear pad.
    Pergunte ao FixBot
    Comentar
  2. Sennheiser RS120 Battery Replacement, Battery: passo 2, imagem 1 %32 Sennheiser RS120 Battery Replacement, Battery: passo 2, imagem 2 %32
    • Twist the left ear pad counterclockwise to reveal the battery compartment within the headphone.
    • To remove batteries, push inward and lift up.
    • The battery should be able to pop out.
    Pergunte ao FixBot
    Comentar
Conclusão
17 outras pessoas executaram este guia.
Gayle Dunham
Membro desde: 03/03/10
393 Reputação
Autoria de 1 guia
8Comentários do guia
Thanks for the information - this made changing the batteries a snap.
Jim K - Responder Compartilhar
Extremely helpful. Thank you!
-Randy N
Randy - Responder Compartilhar
I own three sets and one quit working. As it turns out that the rechargeable batteries in that one set need replacing.
Until I purchase some rechargeable batteries, I am using standard AAA batteries and just have to remember NOT to put the headset back on the cradle.
Thanks for the info on how to access the batteries !
mcgilljp - Responder Compartilhar
Thanks! You solved my mystery.
Marilyn Carini - Responder Compartilhar
Good information, I wouldn’t have had a clue without it. Many thanks
Geoff Smith - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 121
Ao todo: 48,852
