Ir para o conteúdo principal
Sennheiser HD 4.50 Battery Replacement
O que você precisa
  1. Sennheiser HD 4.50 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the side designation on the headband-earpiece junction.
    • The battery is on the left side.
    • The motherboard is on the right side.
  2. Sennheiser HD 4.50 Battery Replacement: passo 2, imagem 1 %32 Sennheiser HD 4.50 Battery Replacement: passo 2, imagem 2 %32 Sennheiser HD 4.50 Battery Replacement: passo 2, imagem 3 %32
  3. Sennheiser HD 4.50 Battery Replacement: passo 3, imagem 1 %32 Sennheiser HD 4.50 Battery Replacement: passo 3, imagem 2 %32 Sennheiser HD 4.50 Battery Replacement: passo 3, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the four 10 mm screws holding the ear cup cover in place.
    • Use an opening tool to pry open the cover.
    • Remove the cover.
  4. Sennheiser HD 4.50 Battery Replacement: passo 4, imagem 1 %32
    • Use a spudger to pry the battery from the plastic case.
    • The battery is held down by a strong adhesive, so it will give resistance.
  5. Sennheiser HD 4.50 Battery Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, pull the white battery connector upwards out of its socket.
    • Remove the battery.
Conclusão
7 outras pessoas executaram este guia.
6 comentários
Hello ! Thanks for the tuto. Do you know where to buy the battery ?
Fren6 - Responder
You can search with the part number(Shown in the photo) : AHB622540N1/AHB622540N01.
Santanu Ghosal - Responder
Where i can find it
Erik Ridwan -
Does anyone know if I can use the he 450 bt replacement battery in a 350 bt headphone? The difference in the spec is that the 450’s battery has a longer battery life (2.2 wh vs. 1.3 wh)
M Lawson - Responder
This was pretty straightforward, but in opening the cap one of the tiny soldered wires pulled off the pad. It's so tiny that I don't have much hope of soldering it back. Any other way to reattach it? I put it back together anyways and now the right cup works fine, but the left is dead. I recommend a warning here about the little wires, if nothing else.
David Hook - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 125
Últimos 30 dias: 571
Duração total: 12,969
