Introdução
In this guide we dissassemble the Sega Master System II
O que você precisa
Vídeo de Apresentação
Remove the 5 screws (3 at the back and 2 on the front)
Remove the screw at the side (this screws is different then the other 5 so remember to put them away from the other 5 screws since they are similar)
This screw is for the rf shield under for the voltage regulator under this bigger rf shield, its not needed to remove that screw
Screenshots taken from a video by Global Garage
3 outras pessoas executaram este guia.
3Comentários do guia
This is in the wrong section.
Nope, its in the Sega Master System area.
Not a Master System
