Ir para o conteúdo principal
Sega Genesis Power LED Replacement
O que você precisa
    1. Sega Genesis Power LED Replacement, Outer Case: passo 1, imagem 1 %32
      • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Sega Genesis Power LED Replacement: passo 2, imagem 1 %32
      • Flip the Sega Genesis upright.
      Pergunte ao FixBot
      Comentar
    3. Sega Genesis Power LED Replacement: passo 3, imagem 1 %32
      • Gently lift the top casing.
      • Note: the case will be connected to the main board by LED wires.
      Pergunte ao FixBot
      Comentar
    4. Sega Genesis Power LED Replacement: passo 4, imagem 1 %32
      • Bend out the LED leads into vertical positions.
      Pergunte ao FixBot
      Comentar
    5. Sega Genesis Power LED Replacement: passo 5, imagem 1 %32
      • Slide the LED wire apparatus off the lead pins.
      • Note: observe which color wire corresponds with which length of pin.
      Pergunte ao FixBot
      Comentar
    6. Sega Genesis Power LED Replacement: passo 6, imagem 1 %32
      • Separate the main board from the outer case.
      Pergunte ao FixBot
      Comentar
    1. Sega Genesis Power LED Replacement, Power LED: passo 7, imagem 1 %32
      • Remove plastic "Power / On" cover by pushing tabs together.
      Pergunte ao FixBot
      Comentar
    2. Sega Genesis Power LED Replacement: passo 8, imagem 1 %32
      • Pull "Power / On" cover away from the console cover.
      Pergunte ao FixBot
      Comentar
    3. Sega Genesis Power LED Replacement: passo 9, imagem 1 %32
      • From the outside of the top cover, remove LED.
      Pergunte ao FixBot
      Comentar
    4. Sega Genesis Power LED Replacement: passo 10, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    5. Sega Genesis Power LED Replacement: passo 11, imagem 1 %32
      • Re-insert "Power / On" cover until it clicks into place.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. When installing the new LED, make sure that the longer of the two legs is inserted into the side of the connector with the red wire.
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 3-29, Regan Fall 2010 Membro de Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Membros
Autoria de 55 guias
5Comentários do guia
My LED won't turn on when I turn on the machine though when I took it out and touched it on a battery it lit up. Did I put it back in wrong or what?
Brandon - Responder Compartilhar
Long leg on the LED goes to the red wire.
Short leg to the white wire. If that's not the case, you may have burned the LED or the spot doesn't work anymore.
Last attempt would be getting your +V5 from the resistor below as shown in this image.
http://i.imgur.com/TucGEXj.jpg
Thunder....16
PIero Bogani - Responder Compartilhar
The model I am trying to change the led on is the 1601 HD graphics Genesis. The problem I have is there are NO simple easy press tabs to pop off the red ring. What is the correct way to remove the LED on this model? Thank you for your time.
snoopydaturd - Responder Compartilhar
Hey snoopy don't give up hope I made a video on how to fix your problem check out this video
https://youtu.be/HJPyhfy56a0
thebigtoe_98 - Responder Compartilhar
Does anybody have any advice on how to replace the LED cable from the motherboard? Guess which numpty snapped it at the solder point.
Dboins - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 24
Últimos 30 dias: 120
Ao todo: 21,643
