Ir para o conteúdo principal
Scuf Reflex Thumbsticks Replacement
O que você precisa
  1. Scuf Reflex Thumbsticks Replacement, Pry up the right faceplate trim edge: passo 1, imagem 1 %32 Scuf Reflex Thumbsticks Replacement, Pry up the right faceplate trim edge: passo 1, imagem 2 %32 Scuf Reflex Thumbsticks Replacement, Pry up the right faceplate trim edge: passo 1, imagem 3 %32
    • The faceplate trim is secured by plastic clips.
    • At the bottom tip of the right grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
    • Pry up to release the faceplate trim’s bottom right clip.
  2. Scuf Reflex Thumbsticks Replacement, Pry up the left faceplate trim edge: passo 2, imagem 1 %32 Scuf Reflex Thumbsticks Replacement, Pry up the left faceplate trim edge: passo 2, imagem 2 %32 Scuf Reflex Thumbsticks Replacement, Pry up the left faceplate trim edge: passo 2, imagem 3 %32
    • At the bottom tip of the left grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
    • Pry up to release the faceplate trim’s bottom left clip.
  3. Scuf Reflex Thumbsticks Replacement, Pry up the center of the faceplate trim: passo 3, imagem 1 %32 Scuf Reflex Thumbsticks Replacement, Pry up the center of the faceplate trim: passo 3, imagem 2 %32
    • Insert the flat end of a spudger between the faceplate trim and the back cover, next to the headphone jack.
    • Pry up to release the plastic clips securing the center of the faceplate trim.
  4. Scuf Reflex Thumbsticks Replacement, Remove the faceplate trim: passo 4, imagem 1 %32 Scuf Reflex Thumbsticks Replacement, Remove the faceplate trim: passo 4, imagem 2 %32 Scuf Reflex Thumbsticks Replacement, Remove the faceplate trim: passo 4, imagem 3 %32
    • The top corners of the faceplate trim are slotted up underneath the faceplate.
    • Lift the bottom edge of the faceplate trim and thread it up and over the thumbsticks.
    • Pull the top corners of the faceplate trim out from underneath the faceplate and remove the faceplate trim.
    • To reinstall the faceplate trim, slide its top corners under the faceplate and over the thumbsticks, then push down along the edges of the trim to engage the clips securing it.
  5. Scuf Reflex Thumbsticks Replacement, Remove the thumbsticks: passo 5, imagem 1 %32 Scuf Reflex Thumbsticks Replacement, Remove the thumbsticks: passo 5, imagem 2 %32 Scuf Reflex Thumbsticks Replacement, Remove the thumbsticks: passo 5, imagem 3 %32
    • Pull the thumbsticks straight up and off of their joysticks to remove them.
    • To reinstall the thumbsticks, place them in their original position and push down until they lock in place.
Conclusão
To reassemble your device, follow the instructions in reverse order.
8 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
255.015 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
124 Membros
Autoria de 25.061 guias
1Comentário do guia
Actually, the base of the thumbsticks is bigger and you can't pull it up. I really don't know if the new models are different.
I had to release the entire top cover.
Igor Minoru - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 82
Últimos 30 dias: 394
Ao todo: 8,528
