Ir para o conteúdo principal
Schwinn Tourist Inner Tube Replacement
O que você precisa
  1. Schwinn Tourist Inner Tube Replacement, Front Inner Tube: passo 1, imagem 1 %32
    • Flip the bicycle upside down.
    • By flipping the bicycle upside down it will offer additional support by being able to stand up by itself.
    Pergunte ao FixBot
    Comentar
  2. Schwinn Tourist Inner Tube Replacement, Loosen The Brakes: passo 2, imagem 1 %32
    • Apply pressure to both sides of the brake arm with one hand and lift the metal brake cable from the brake caliper.
    • By releasing the brake cable from the brake caliper, it will loosen the brake pads by the tire.
    Pergunte ao FixBot
    Comentar
  3. Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: passo 3, imagem 1 %32 Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: passo 3, imagem 2 %32
    • Push the quick release lever outwards towards your body.
    • While holding the other end of the quick release lever, rotate the lever counter-clockwise until it is loose.
    Pergunte ao FixBot
    Comentar
  4. Schwinn Tourist Inner Tube Replacement, Remove Tire: passo 4, imagem 1 %32
    • Lift the tire to remove it from the bicycle.
    Pergunte ao FixBot
    Comentar
  5. Schwinn Tourist Inner Tube Replacement, Inserting The Tire Lever: passo 5, imagem 1 %32
    • Insert the flat end of the tire lever between the inside wall of the tire and the outside of the rim.
    • Attach the other end of the tire lever to the nearest spoke on the rim.
    Pergunte ao FixBot
    Comentar
  6. Schwinn Tourist Inner Tube Replacement, Insering Second Tire Lever: passo 6, imagem 1 %32
    • Insert a second tire lever next to the first lever to create leverage for releasing the tire from the rim.
    Pergunte ao FixBot
    Comentar
  7. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: passo 7, imagem 1 %32
    • Leave the first lever in place. Slide the second lever against the outside edge of the rim until one side of the tire is off of the rim.
    Pergunte ao FixBot
    Comentar
  8. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: passo 8, imagem 1 %32
    • Reattach the the first lever to the other side of the tire and repeat steps 4-7 to remove tire completely from rim.
    Pergunte ao FixBot
    Comentar
  9. Schwinn Tourist Inner Tube Replacement, Remove the Valve Stem: passo 9, imagem 1 %32
    • Push the valve stem upwards through the hole in the rim.
    Pergunte ao FixBot
    Comentar
  10. Schwinn Tourist Inner Tube Replacement, Finished: passo 10, imagem 1 %32
    • Once valve stem is pushed, pull the inner tube until it is completely removed from the rim.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Quandre Mebane
Membro desde: 10/07/14
149 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-22, Donnelly Fall 2014 Membro de USF Tampa, Team 1-22, Donnelly Fall 2014
USFT-DONNELLY-F14S1G22
1 Membro
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 42
Ao todo: 5,600
