Ir para o conteúdo principal
Satin Stitch a Tear in Your Shirt
O que você precisa
  1. Satin Stitch a Tear in Your Shirt, Tear: passo 1, imagem 1 %32
    • Examine the tear and the surrounding fabric.
    • Clip any loose threads to keep them from getting caught in the new stitching.
    • Select a coordinating color of thread and thread the sewing machine.
  2. Satin Stitch a Tear in Your Shirt: passo 2, imagem 1 %32
    • Adjust the sewing machine to a stitch-width of two or three.
    • Stitch-width controls the sideways distance of the stitch, so if you feel you need a little more width, three is acceptable.
    • Every sewing machine is different, so refer to your sewing machine manual to find the stitch width adjustment on your machine.
    • Be sure your sewing machine is fitted with a wide-mouthed pressor foot, as opposed to one with a small round hole. When the sewing machine does a satin stitch, it will bump into the the pressor foot and break if there is not a wide enough opening.
  3. Satin Stitch a Tear in Your Shirt: passo 3, imagem 1 %32
    • Set the sewing machine stitch length down to just above zero.
    • Stitch length controls how far forward the sewing machine advances with each stitch. Satin stitches should be very tight, which is why we want this number very close to zero.
    • Every sewing machine is different, so refer to your sewing machine manual to find the stitch length adjustment on your machine.
  4. Satin Stitch a Tear in Your Shirt: passo 4, imagem 1 %32 Satin Stitch a Tear in Your Shirt: passo 4, imagem 2 %32
    • If the fabric you’re repairing is gauzy or thin, you can add a small scrap of interfacing or scrap fabric on the backside of your rip or tear. Most of the time this isn’t necessary.
    • Align the fabric in the sewing machine about half an inch before the rip or tear.
    • Lower the pressor foot and begin sewing, guiding the machine over the tear.
  5. Satin Stitch a Tear in Your Shirt: passo 5, imagem 1 %32 Satin Stitch a Tear in Your Shirt: passo 5, imagem 2 %32
    • Sew about half an inch past the end of the slit.
    • Lift the presser foot and clip the threads to free the garment.
  6. Satin Stitch a Tear in Your Shirt: passo 6, imagem 1 %32 Satin Stitch a Tear in Your Shirt: passo 6, imagem 2 %32
    • Trim any extra threads.
    • Admire your handiwork.
Linha de Chegada
10 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.128 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.067 guias
3 comentários
it repaired hannedil
Shafikahmed - Responder
Now we can save a beloved, very old Patagonia shirt
Josiah M. Daniel III - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 36
Últimos 7 dias: 203
Últimos 30 dias: 1,002
Duração total: 73,300
