Ir para o conteúdo principal
Sanyo VPC-T850 Shutter Button Replacement
O que você precisa
    1. Sanyo VPC-T850 Shutter Button Replacement, Battery: passo 1, imagem 1 %32
      • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
      Pergunte ao FixBot
      Comentar
    2. Sanyo VPC-T850 Shutter Button Replacement: passo 2, imagem 1 %32
      • Locate the hatch found on the bottom of the camera.
      • Open the hatch by gripping the small notch and sliding it outwards.
      Pergunte ao FixBot
      Comentar
    3. Sanyo VPC-T850 Shutter Button Replacement: passo 3, imagem 1 %32
      • Push the small, plastic arm out of the way to free the battery.
      • The battery is spring loaded and will pop out slightly when the arm is moved.
      Pergunte ao FixBot
      Comentar
    4. Sanyo VPC-T850 Shutter Button Replacement: passo 4, imagem 1 %32
      • Pull the battery out of the camera and close the hatch.
      • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
      Pergunte ao FixBot
      Comentar
    1. Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: passo 5, imagem 1 %32 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: passo 5, imagem 2 %32 Sanyo VPC-T850 Shutter Button Replacement, Outer Casing: passo 5, imagem 3 %32
      • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
      • Be sure to keep track of the side each screw comes from, as they come in different lengths.
      Pergunte ao FixBot
      Comentar
    2. Sanyo VPC-T850 Shutter Button Replacement: passo 6, imagem 1 %32 Sanyo VPC-T850 Shutter Button Replacement: passo 6, imagem 2 %32
      • Orient the camera so the display is facing up.
      • Gently pull off the rear panel surrounding the display.
      • There are still three green wires connecting the panel to the rest of the camera.
      • Use your prying tool if you have difficulties removing the panel by hand.
      Pergunte ao FixBot
      Comentar
    3. Sanyo VPC-T850 Shutter Button Replacement: passo 7, imagem 1 %32
      • Remove the eight black screws connecting the keypad circuit board to the rear panel.
      Pergunte ao FixBot
      Comentar
    4. Sanyo VPC-T850 Shutter Button Replacement: passo 8, imagem 1 %32 Sanyo VPC-T850 Shutter Button Replacement: passo 8, imagem 2 %32
      • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
      Pergunte ao FixBot
      Comentar
    5. Sanyo VPC-T850 Shutter Button Replacement: passo 9, imagem 1 %32
      • Flip the camera over so the lens is facing up.
      • Gently lift up the front panel to remove it from the rest of the camera.
      • Use your plastic opening tool if you have difficulties removing the panel by hand.
      Pergunte ao FixBot
      Comentar
    1. Sanyo VPC-T850 Shutter Button Replacement, Shutter Button: passo 10, imagem 1 %32
      • Find the chrome framing located on the top of the camera.
      • The physical shutter button apparatus is directly attached to this frame.
      Pergunte ao FixBot
      Comentar
    2. Sanyo VPC-T850 Shutter Button Replacement: passo 11, imagem 1 %32 Sanyo VPC-T850 Shutter Button Replacement: passo 11, imagem 2 %32
      • Remove the three black screws connecting the chrome frame to the camera.
      • Three screws are located toward the front, with the remaining one above the display.
      Pergunte ao FixBot
      Comentar
    3. Sanyo VPC-T850 Shutter Button Replacement: passo 12, imagem 1 %32
      • Gently remove the loosened chrome frame and connected shutter button from the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
James Robinson
Membro desde: 10/27/15
459 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 42
Ao todo: 688
