Ir para o conteúdo principal
Sanyo VPC-T850 LCD Display Replacement
O que você precisa
    1. Sanyo VPC-T850 LCD Display Replacement, Battery: passo 1, imagem 1 %32
      • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
      Pergunte ao FixBot
      Comentar
    2. Sanyo VPC-T850 LCD Display Replacement: passo 2, imagem 1 %32
      • Locate the hatch found on the bottom of the camera.
      • Open the hatch by gripping the small notch and sliding it outwards.
      Pergunte ao FixBot
      Comentar
    3. Sanyo VPC-T850 LCD Display Replacement: passo 3, imagem 1 %32
      • Push the small, plastic arm out of the way to free the battery.
      • The battery is spring loaded and will pop out slightly when the arm is moved.
      Pergunte ao FixBot
      Comentar
    4. Sanyo VPC-T850 LCD Display Replacement: passo 4, imagem 1 %32
      • Pull the battery out of the camera and close the hatch.
      • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
      Pergunte ao FixBot
      Comentar
    1. Sanyo VPC-T850 LCD Display Replacement, Outer Casing: passo 5, imagem 1 %32 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: passo 5, imagem 2 %32 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: passo 5, imagem 3 %32
      • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
      • Be sure to keep track of the side each screw comes from, as they come in different lengths.
      Pergunte ao FixBot
      Comentar
    2. Sanyo VPC-T850 LCD Display Replacement: passo 6, imagem 1 %32 Sanyo VPC-T850 LCD Display Replacement: passo 6, imagem 2 %32
      • Orient the camera so the display is facing up.
      • Gently pull off the rear panel surrounding the display.
      • There are still three green wires connecting the panel to the rest of the camera.
      • Use your prying tool if you have difficulties removing the panel by hand.
      Pergunte ao FixBot
      Comentar
    3. Sanyo VPC-T850 LCD Display Replacement: passo 7, imagem 1 %32
      • Remove the eight black screws connecting the keypad circuit board to the rear panel.
      Pergunte ao FixBot
      Comentar
    4. Sanyo VPC-T850 LCD Display Replacement: passo 8, imagem 1 %32 Sanyo VPC-T850 LCD Display Replacement: passo 8, imagem 2 %32
      • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
      Pergunte ao FixBot
      Comentar
    5. Sanyo VPC-T850 LCD Display Replacement: passo 9, imagem 1 %32
      • Flip the camera over so the lens is facing up.
      • Gently lift up the front panel to remove it from the rest of the camera.
      • Use your plastic opening tool if you have difficulties removing the panel by hand.
      Pergunte ao FixBot
      Comentar
    1. Sanyo VPC-T850 LCD Display Replacement, LCD Display: passo 10, imagem 1 %32
      • Flip the device over to where the display is located.
      • Using your plastic opening tool, lift the display out of its metal housing.
      Pergunte ao FixBot
      Comentar
    2. Sanyo VPC-T850 LCD Display Replacement: passo 11, imagem 1 %32
      • Locate the orange ribbon connecting the display to the camera.
      • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
      Pergunte ao FixBot
      Comentar
    3. Sanyo VPC-T850 LCD Display Replacement: passo 12, imagem 1 %32
      • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
      • Pull slowly to avoid severing the orange ribbon from the display.
      Pergunte ao FixBot
      Comentar
Conclusão
Devin Farnsworth
Membro desde: 10/29/15
101 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 43
Ao todo: 819
