Introdução
Use this guide to replace the function set.
O que você precisa
Place your thumb on the right side of the camera over the battery door.
Slide the battery door to the right until the door lifts up.
Remove the following six screws using the Phillips #00 screwdriver:
Two screws on the left side of the camera.
Two screws on the right side of the camera.
Two screws on the bottom of the camera.
Remove the function set strip by lifting it from the inside of the rear case.
The function strip is now free from the camera.
