Ir para o conteúdo principal
Sanyo SCP-8100 Keypad Replacement
O que você precisa
  1. Sanyo SCP-8100 Keypad Replacement, Battery: passo 1, imagem 1 %32 Sanyo SCP-8100 Keypad Replacement, Battery: passo 1, imagem 2 %32 Sanyo SCP-8100 Keypad Replacement, Battery: passo 1, imagem 3 %32
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. Sanyo SCP-8100 Keypad Replacement, Back Panel: passo 2, imagem 1 %32 Sanyo SCP-8100 Keypad Replacement, Back Panel: passo 2, imagem 2 %32
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
    Pergunte ao FixBot
    Comentar
  3. Sanyo SCP-8100 Keypad Replacement: passo 3, imagem 1 %32
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Sanyo SCP-8100 Keypad Replacement: passo 4, imagem 1 %32 Sanyo SCP-8100 Keypad Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
    Pergunte ao FixBot
    Comentar
  5. Sanyo SCP-8100 Keypad Replacement: passo 5, imagem 1 %32 Sanyo SCP-8100 Keypad Replacement: passo 5, imagem 2 %32 Sanyo SCP-8100 Keypad Replacement: passo 5, imagem 3 %32
    • While removing the back panel, take out the rubber cover on each side.
    Pergunte ao FixBot
    Comentar
  6. Sanyo SCP-8100 Keypad Replacement, Keypad: passo 6, imagem 1 %32 Sanyo SCP-8100 Keypad Replacement, Keypad: passo 6, imagem 2 %32
    • Pull the volume and camera buttons off from the side of the phone.
    Pergunte ao FixBot
    Comentar
  7. Sanyo SCP-8100 Keypad Replacement: passo 7, imagem 1 %32 Sanyo SCP-8100 Keypad Replacement: passo 7, imagem 2 %32
    • Pull the gray frame covering the charging port from the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  8. Sanyo SCP-8100 Keypad Replacement: passo 8, imagem 1 %32 Sanyo SCP-8100 Keypad Replacement: passo 8, imagem 2 %32
    • Use the opening tool to lift the motherboard up from the phone.
    • Be careful and pry the motherboard off slowly. The motherboard will be attached to the phone at the top by a metal ribbon.
    Pergunte ao FixBot
    Comentar
  9. Sanyo SCP-8100 Keypad Replacement: passo 9, imagem 1 %32 Sanyo SCP-8100 Keypad Replacement: passo 9, imagem 2 %32 Sanyo SCP-8100 Keypad Replacement: passo 9, imagem 3 %32
    • Flip open the phone, exposing the keypad.
    • Use the opening tool to push the buttons from the bottom to lift the rubber keypad up.
    • Pull the keypad out of the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Irenz Afable
Membro desde: 04/15/13
57 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-41, Amido Spring 2013 Membro de Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 24
Ao todo: 665
