Ir para o conteúdo principal
Sanyo S1414 LCD Replacement
O que você precisa
  1. Sanyo S1414 LCD Replacement, LCD: passo 1, imagem 1 %32 Sanyo S1414 LCD Replacement, LCD: passo 1, imagem 2 %32 Sanyo S1414 LCD Replacement, LCD: passo 1, imagem 3 %32
    • Remove the batteries and the memory card if so equipped.
    • Remove the two Phillips screws on the right.
    • Remove the four Phillips screws on the bottom.
  2. Sanyo S1414 LCD Replacement: passo 2, imagem 1 %32 Sanyo S1414 LCD Replacement: passo 2, imagem 2 %32 Sanyo S1414 LCD Replacement: passo 2, imagem 3 %32
    • Remove the two screws on the left.
    • With all the screws removed, the case will split easy. No tool is required.
    • Front and back case come off at the same time. the silver midframe that houses the top buttons, remains on the camera.
  3. Sanyo S1414 LCD Replacement: passo 3, imagem 1 %32 Sanyo S1414 LCD Replacement: passo 3, imagem 2 %32 Sanyo S1414 LCD Replacement: passo 3, imagem 3 %32
    • The LCD ribbon cable is folded under the holder. Do not try to remove the LCD yet. It will tear the ribbon cable.
    • Fold the LCD way from the holder. Remove the four screws that secure the holder to the logic board.
    • With the LCD holder out of the way, you can now open the ribbon cable connector. Use your fingernails to flip the white clasp away from the ribbon cable side. This will disconnect the cable. Remove the LCD and replace with the new one.
Conclusão
oldturkey03
Membro desde: 09/29/10
791.325 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 35
Autoria de 603 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 1,024
