Ir para o conteúdo principal
Sanyo Katana Screen Replacement
O que você precisa
  1. Sanyo Katana Screen Replacement, Screen Protector: passo 1, imagem 1 %32 Sanyo Katana Screen Replacement, Screen Protector: passo 1, imagem 2 %32
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
    Pergunte ao FixBot
    Comentar
  2. Sanyo Katana Screen Replacement: passo 2, imagem 1 %32 Sanyo Katana Screen Replacement: passo 2, imagem 2 %32
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Sanyo Katana Screen Replacement: passo 3, imagem 1 %32 Sanyo Katana Screen Replacement: passo 3, imagem 2 %32
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
    Pergunte ao FixBot
    Comentar
  4. Sanyo Katana Screen Replacement, Front Case: passo 4, imagem 1 %32 Sanyo Katana Screen Replacement, Front Case: passo 4, imagem 2 %32 Sanyo Katana Screen Replacement, Front Case: passo 4, imagem 3 %32
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
    Pergunte ao FixBot
    Comentar
  5. Sanyo Katana Screen Replacement, Screen: passo 5, imagem 1 %32 Sanyo Katana Screen Replacement, Screen: passo 5, imagem 2 %32
    • Using a Tri-wing Y0 screwdriver, remove the 4.4mm screw.
    • Use fingers to remove the strip from the device.
    Pergunte ao FixBot
    Comentar
  6. Sanyo Katana Screen Replacement: passo 6, imagem 1 %32 Sanyo Katana Screen Replacement: passo 6, imagem 2 %32 Sanyo Katana Screen Replacement: passo 6, imagem 3 %32
    • Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen.
    Pergunte ao FixBot
    Comentar
  7. Sanyo Katana Screen Replacement: passo 7, imagem 1 %32 Sanyo Katana Screen Replacement: passo 7, imagem 2 %32
    • Use the flat edge of the spudger to detach the screen from the phone casing.
    • Pull the screen up and away from the case.
    Pergunte ao FixBot
    Comentar
Conclusão
Aliceann
Membro desde: 03/11/13
49 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 12-1, Benson Spring 2013 Membro de Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 57
Últimos 30 dias: 80
Ao todo: 1,038
