Ir para o conteúdo principal
Samsung Watch Active Motherboard Replacement
O que você precisa
  1. Samsung Watch Active Motherboard Replacement, Turn off the watch: passo 1, imagem 1 %32 Samsung Watch Active Motherboard Replacement, Turn off the watch: passo 1, imagem 2 %32
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Watch Active Motherboard Replacement, Remove the rear screws: passo 2, imagem 1 %32
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Watch Active Motherboard Replacement, Separate the back cover from the housing: passo 3, imagem 1 %32 Samsung Watch Active Motherboard Replacement, Separate the back cover from the housing: passo 3, imagem 2 %32 Samsung Watch Active Motherboard Replacement, Separate the back cover from the housing: passo 3, imagem 3 %32
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Watch Active Motherboard Replacement, Disconnect the sensor array: passo 4, imagem 1 %32 Samsung Watch Active Motherboard Replacement, Disconnect the sensor array: passo 4, imagem 2 %32
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Watch Active Motherboard Replacement, Remove the back cover: passo 5, imagem 1 %32
    • Remove the back cover.
  6. Samsung Watch Active Motherboard Replacement, Disconnect the motherboard: passo 6, imagem 1 %32 Samsung Watch Active Motherboard Replacement, Disconnect the motherboard: passo 6, imagem 2 %32 Samsung Watch Active Motherboard Replacement, Disconnect the motherboard: passo 6, imagem 3 %32
    • Use the flat end of a spudger to disconnect the display assembly, the microphone and pressure sensor array, and side button.
  7. Samsung Watch Active Motherboard Replacement, Undo the mic tape: passo 7, imagem 1 %32 Samsung Watch Active Motherboard Replacement, Undo the mic tape: passo 7, imagem 2 %32 Samsung Watch Active Motherboard Replacement, Undo the mic tape: passo 7, imagem 3 %32
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
  8. Samsung Watch Active Motherboard Replacement, Remove the motherboard screw: passo 8, imagem 1 %32
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
  9. Samsung Watch Active Motherboard Replacement, Loosen the motherboard: passo 9, imagem 1 %32 Samsung Watch Active Motherboard Replacement, Loosen the motherboard: passo 9, imagem 2 %32 Samsung Watch Active Motherboard Replacement, Loosen the motherboard: passo 9, imagem 3 %32
    • Use an opening pick to loosen the motherboard from the core assembly.
    • The plastic tab holding the motherboard in place is fragile, so don't lift the motherboard up until it has cleared the tab.
  10. Samsung Watch Active Motherboard Replacement, Remove the motherboard: passo 10, imagem 1 %32 Samsung Watch Active Motherboard Replacement, Remove the motherboard: passo 10, imagem 2 %32 Samsung Watch Active Motherboard Replacement, Remove the motherboard: passo 10, imagem 3 %32
    • Slide the motherboard out from under the plastic tab to remove it.
Conclusão
3 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
124.137 Reputação
Autoria de 189 guias
Equipe
Um comentário
Sir can you help ME with power switch lines
Tupper Mendoza - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 2,542
