Ir para o conteúdo principal
Samsung WB850F Control Panel Replacement
O que você precisa
    1. Samsung WB850F Control Panel Replacement, Control Panel: passo 1, imagem 1 %32 Samsung WB850F Control Panel Replacement, Control Panel: passo 1, imagem 2 %32 Samsung WB850F Control Panel Replacement, Control Panel: passo 1, imagem 3 %32
      • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
      • 2 screws are located on the bottom.
      • 2 screws are located on the left side. (HDMI port)
      • 2 screws are located on the right side of the camera. (Opposite HDMI side)
      Pergunte ao FixBot
      Comentar
    2. Samsung WB850F Control Panel Replacement: passo 2, imagem 1 %32
      • To remove the back screen case, use the blue opening tool to open the case up from the right side.
      Pergunte ao FixBot
      Comentar
    3. Samsung WB850F Control Panel Replacement: passo 3, imagem 1 %32 Samsung WB850F Control Panel Replacement: passo 3, imagem 2 %32
      • Use screwdriver to remove control panel screw.
      • Lift up control panel from the side where the screw was just removed.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 12-4, Eyestone Spring 2016 Membro de USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Membros
Autoria de 8 guias
1Comentário do guia
Only problem .. Where can I buy a replacement control panel.
D Traynor - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 1,128
