Ir para o conteúdo principal
Samsung WB350F Screen Replacement
O que você precisa
    1. Samsung WB350F Screen Replacement, Rear Case: passo 1, imagem 1 %32 Samsung WB350F Screen Replacement, Rear Case: passo 1, imagem 2 %32 Samsung WB350F Screen Replacement, Rear Case: passo 1, imagem 3 %32
      • Remove the wristlet strap.
      • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
      Pergunte ao FixBot
      Comentar
    2. Samsung WB350F Screen Replacement: passo 2, imagem 1 %32 Samsung WB350F Screen Replacement: passo 2, imagem 2 %32 Samsung WB350F Screen Replacement: passo 2, imagem 3 %32
      • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
      • There is one silver screw on the bottom and two black screws on each side.
      • Keep the screws together for an easier re-assembly later.
      Pergunte ao FixBot
      Comentar
    3. Samsung WB350F Screen Replacement: passo 3, imagem 1 %32 Samsung WB350F Screen Replacement: passo 3, imagem 2 %32 Samsung WB350F Screen Replacement: passo 3, imagem 3 %32
      • Open the case of the camera using your plastic opening tool.
      • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
      • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
      Pergunte ao FixBot
      Comentar
    4. Samsung WB350F Screen Replacement: passo 4, imagem 1 %32
      • Remove the plastic casing, exposing the inner workings of the camera.
      Pergunte ao FixBot
      Comentar
    1. Samsung WB350F Screen Replacement, Screen: passo 5, imagem 1 %32 Samsung WB350F Screen Replacement, Screen: passo 5, imagem 2 %32
      • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
      • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
      Pergunte ao FixBot
      Comentar
    2. Samsung WB350F Screen Replacement: passo 6, imagem 1 %32
      • Move the menu button panel to the right as well as the screen.
      • Be careful because each are connected to the camera by a ribbon.
      Pergunte ao FixBot
      Comentar
    3. Samsung WB350F Screen Replacement: passo 7, imagem 1 %32
      • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Samsung WB350F Screen Replacement: passo 8, imagem 1 %32 Samsung WB350F Screen Replacement: passo 8, imagem 2 %32
      • Remove the silver panel.
      Pergunte ao FixBot
      Comentar
    5. Samsung WB350F Screen Replacement: passo 9, imagem 1 %32 Samsung WB350F Screen Replacement: passo 9, imagem 2 %32
      • Flip the screen back over.
      • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
      Pergunte ao FixBot
      Comentar
    6. Samsung WB350F Screen Replacement: passo 10, imagem 1 %32 Samsung WB350F Screen Replacement: passo 10, imagem 2 %32
      • Carefully detach both ribbons by gently pulling one at a time.
      • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
      • Be sure to pull gently as you do not want to break either ribbon.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Casey Bernier
Membro desde: 03/04/16
131 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
Broke my screen, bought a new one on the internet (ebay) and used this tutorial for replacement.
Good photos and every step is clear to follow
Gerald Heidrich - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 38
Ao todo: 2,274
