Ir para o conteúdo principal
Samsung WB1100F Camera Lens Replacement
O que você precisa
  1. Samsung WB1100F Camera Lens Replacement, LCD Screen Cover: passo 1, imagem 1 %32 Samsung WB1100F Camera Lens Replacement, LCD Screen Cover: passo 1, imagem 2 %32
    • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
    • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
    Pergunte ao FixBot
    Comentar
  2. Samsung WB1100F Camera Lens Replacement: passo 2, imagem 1 %32 Samsung WB1100F Camera Lens Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool or spudger if available.
    • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
    Pergunte ao FixBot
    Comentar
  3. Samsung WB1100F Camera Lens Replacement, LCD Screen: passo 3, imagem 1 %32 Samsung WB1100F Camera Lens Replacement, LCD Screen: passo 3, imagem 2 %32
    • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
    Pergunte ao FixBot
    Comentar
  4. Samsung WB1100F Camera Lens Replacement: passo 4, imagem 1 %32 Samsung WB1100F Camera Lens Replacement: passo 4, imagem 2 %32 Samsung WB1100F Camera Lens Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Flip the LCD screen over to reveal the display cable.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
    Pergunte ao FixBot
    Comentar
  5. Samsung WB1100F Camera Lens Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove two 1.2 Phillips #00 screws connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Samsung WB1100F Camera Lens Replacement: passo 6, imagem 1 %32
    • Desolder five wires connected to the camera motherboard.
    Pergunte ao FixBot
    Comentar
  7. Samsung WB1100F Camera Lens Replacement: passo 7, imagem 1 %32 Samsung WB1100F Camera Lens Replacement: passo 7, imagem 2 %32
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps on the five ZIF connectors on the motherboard.
    • Detach the five ribbon cables from the camera motherboard.
    • The white line on the ribbon cables mark the edge of the connection area. To reinstall, insert the cables into the connector up to this line, and then close the retaining flap. If a cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
    Pergunte ao FixBot
    Comentar
  8. Samsung WB1100F Camera Lens Replacement: passo 8, imagem 1 %32
    • Gently remove the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Samsung WB1100F Camera Lens Replacement, Camera Lens: passo 9, imagem 1 %32
    • Remove the three 1.5 mm Phillips #1 screws connected to the lens assembly.
    Pergunte ao FixBot
    Comentar
  10. Samsung WB1100F Camera Lens Replacement: passo 10, imagem 1 %32 Samsung WB1100F Camera Lens Replacement: passo 10, imagem 2 %32
    • Pull the lens assembly from main body of the camera, using a spudger to pry if necessary.
    Pergunte ao FixBot
    Comentar
Conclusão
Jesse Lindsey
Membro desde: 05/13/16
581 Reputação
Autoria de 5 guias
Equipe
Metro State, Team 1-1, Carpenter SU 2016 Membro de Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 62
Ao todo: 3,607
