Ir para o conteúdo principal
Samsung WB1100F Camera Flash Replacement
O que você precisa
  1. Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: passo 1, imagem 1 %32 Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: passo 1, imagem 2 %32
    • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
    • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
  2. Samsung WB1100F Camera Flash Replacement: passo 2, imagem 1 %32 Samsung WB1100F Camera Flash Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool or spudger if available.
    • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
  3. Samsung WB1100F Camera Flash Replacement, Camera Flash: passo 3, imagem 1 %32 Samsung WB1100F Camera Flash Replacement, Camera Flash: passo 3, imagem 2 %32 Samsung WB1100F Camera Flash Replacement, Camera Flash: passo 3, imagem 3 %32
    • Remove four 1.2 mm Phillips #00 screws from the top panel.
  4. Samsung WB1100F Camera Flash Replacement: passo 4, imagem 1 %32
    • Using the flat end of a spudger, loosen the connection between the top panel and the device. Remove the top panel using your hands.
  5. Samsung WB1100F Camera Flash Replacement: passo 5, imagem 1 %32
    • Remove four 1.2 mm Phillips #00 screws from the flash assembly
  6. Samsung WB1100F Camera Flash Replacement: passo 6, imagem 1 %32
    • Using your hands, remove the flash assembly. This should not require much force.
  7. Samsung WB1100F Camera Flash Replacement: passo 7, imagem 1 %32 Samsung WB1100F Camera Flash Replacement: passo 7, imagem 2 %32
    • Using your hands, remove the top flash panel by pressuring down on the back to release a locking tab.
  8. Samsung WB1100F Camera Flash Replacement: passo 8, imagem 1 %32
    • Desolder three wires on the flash assembly.
  9. Samsung WB1100F Camera Flash Replacement: passo 9, imagem 1 %32
    • Gently remove the flash assembly from the body.
Conclusão
Jesse Lindsey
Membro desde: 05/13/16
581 Reputação
Autoria de 5 guias
Equipe
Metro State, Team 1-1, Carpenter SU 2016 Membro de Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 614
