Ir para o conteúdo principal
Samsung UBD-KM85C Disc Drive Replacement
O que você precisa
  1. Samsung UBD-KM85C Disc Drive Replacement, Outer Shell: passo 1, imagem 1 %32
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Samsung UBD-KM85C Disc Drive Replacement: passo 2, imagem 1 %32 Samsung UBD-KM85C Disc Drive Replacement: passo 2, imagem 2 %32
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
    Pergunte ao FixBot
    Comentar
  3. Samsung UBD-KM85C Disc Drive Replacement: passo 3, imagem 1 %32 Samsung UBD-KM85C Disc Drive Replacement: passo 3, imagem 2 %32 Samsung UBD-KM85C Disc Drive Replacement: passo 3, imagem 3 %32
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
    Pergunte ao FixBot
    Comentar
  4. Samsung UBD-KM85C Disc Drive Replacement: passo 4, imagem 1 %32
    • Remove the cover from the device.
    Pergunte ao FixBot
    Comentar
  5. Samsung UBD-KM85C Disc Drive Replacement, Disc Drive: passo 5, imagem 1 %32
    • The disk drive is the large metallic rectangular unit that occupies a third of the space inside the unit.
    Pergunte ao FixBot
    Comentar
  6. Samsung UBD-KM85C Disc Drive Replacement: passo 6, imagem 1 %32 Samsung UBD-KM85C Disc Drive Replacement: passo 6, imagem 2 %32
    • The disk drive has four 6.5mm screws located near each of its corners that hold it onto the frame. Use a #1 Phillips head screwdriver to remove these screws.
    Pergunte ao FixBot
    Comentar
  7. Samsung UBD-KM85C Disc Drive Replacement: passo 7, imagem 1 %32 Samsung UBD-KM85C Disc Drive Replacement: passo 7, imagem 2 %32 Samsung UBD-KM85C Disc Drive Replacement: passo 7, imagem 3 %32
    • The disk drive has two connections to the motherboard that can be disconnected by pulling on the blue plastic tabs.
    Pergunte ao FixBot
    Comentar
  8. Samsung UBD-KM85C Disc Drive Replacement: passo 8, imagem 1 %32
    • Once the connections are unplugged and the screws are removed, the disk drive can be lifted out. The previous steps can be done in the reverse order to replace the part.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
James Edwards
Membro desde: 02/01/18
627 Reputação
Autoria de 5 guias
Equipe
Baylor, Team S2-G1, Johnson Spring 2018 Membro de Baylor, Team S2-G1, Johnson Spring 2018
BU-JOHNSON-S18S2G1
3 Membros
Autoria de 6 guias
1Comentário do guia
How do I eject a disk that's stuck in the drive?
Martin Y - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 691
