Ir para o conteúdo principal
Samsung Stratosphere Rear Camera Replacement
O que você precisa
  1. Samsung Stratosphere Rear Camera Replacement, Battery: passo 1, imagem 1 %32
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
    Pergunte ao FixBot
    Comentar
  2. Samsung Stratosphere Rear Camera Replacement: passo 2, imagem 1 %32
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
    Pergunte ao FixBot
    Comentar
  3. Samsung Stratosphere Rear Camera Replacement, Motherboard: passo 3, imagem 1 %32
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
    Pergunte ao FixBot
    Comentar
  4. Samsung Stratosphere Rear Camera Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
    Pergunte ao FixBot
    Comentar
  5. Samsung Stratosphere Rear Camera Replacement: passo 5, imagem 1 %32
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
    Pergunte ao FixBot
    Comentar
  6. Samsung Stratosphere Rear Camera Replacement: passo 6, imagem 1 %32
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Samsung Stratosphere Rear Camera Replacement: passo 7, imagem 1 %32 Samsung Stratosphere Rear Camera Replacement: passo 7, imagem 2 %32
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
    Pergunte ao FixBot
    Comentar
  8. Samsung Stratosphere Rear Camera Replacement: passo 8, imagem 1 %32
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
    Pergunte ao FixBot
    Comentar
  9. Samsung Stratosphere Rear Camera Replacement, Rear Camera: passo 9, imagem 1 %32
    • Gently pull the camera to the left while keeping it as close to the motherboard as possible.
    • The metal foil connector attached to the camera should slide out of the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Ryan
Membro desde: 10/20/13
375 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-32, Amido Fall 2013 Membro de Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 992
