Ir para o conteúdo principal
Samsung Solstice Battery Replacement
O que você precisa
  1. Samsung Solstice Battery Replacement, Removing the back cover: passo 1, imagem 1 %32 Samsung Solstice Battery Replacement, Removing the back cover: passo 1, imagem 2 %32 Samsung Solstice Battery Replacement, Removing the back cover: passo 1, imagem 3 %32
    • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
    Pergunte ao FixBot
    Comentar
  2. Samsung Solstice Battery Replacement, Removing the battery: passo 2, imagem 1 %32 Samsung Solstice Battery Replacement, Removing the battery: passo 2, imagem 2 %32 Samsung Solstice Battery Replacement, Removing the battery: passo 2, imagem 3 %32
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
    • Pry the battery up out of its recess and away from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Colton Glyder
Membro desde: 09/05/14
301 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 20
Ao todo: 638
