Introdução
Use this guide to replace a damaged or broken motherboard.
O que você precisa
Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
Remove 2 3mm screws from the metal plate covering the motherboard and lens using a Phillips #00 screw driver.
3Comentários do guia
Thanks for great info. I should add that one can also clean the sensor. Sensor is circular plate with 3 screws at back of the lens. Now the camera is like new!
Where can you buy a replacement motherboard?
ST76 and ST77 are very close relatives.
As it can be seen on the parts, some are marked: ”ST77”
Paul
