Ir para o conteúdo principal
Samsung ST700 Battery Replacement
    1. Samsung ST700 Battery Replacement, Battery: passo 1, imagem 1 %32
      • The battery is located on the bottom of the camera underneath a latch door
      • To open the latched door, move the latch (circled in the picture) toward the center of the camera, and the door should pop open.
      Pergunte ao FixBot
      Comentar
    2. Samsung ST700 Battery Replacement: passo 2, imagem 1 %32
      • When the bottom componets are exposed, the battery is held by a blue latch. (Blue latch is circled in the picture)
      • Push the blue latch latch to relase the battery from its slot. It should be pushed out.
      • Remove the battery.
      • Move the blue latch to put in the new battery.
      • Make sure that the battery is going in the correct way. The three golden slits should be matching up with three golden prongs on the bottom of the battery holder.
      • Close the latch door over the components and move the latch toward the side of the camera. Trying turning on the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Tanner Studley
Membro desde: 03/04/16
149 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
my baterry inflated with air and now is stuck in the slot, what should i do?
Denix 54 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 49
Ao todo: 1,116
