Ir para o conteúdo principal
Samsung SPEX SCH-R210 antenna Replacement
O que você precisa
  1. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: passo 1, imagem 1 %32 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: passo 1, imagem 2 %32 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: passo 1, imagem 3 %32
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    Pergunte ao FixBot
    Comentar
  2. Samsung SPEX SCH-R210 antenna Replacement, Battery: passo 2, imagem 1 %32
    • Locate the access notch at the end of the battery compartment.
    Pergunte ao FixBot
    Comentar
  3. Samsung SPEX SCH-R210 antenna Replacement: passo 3, imagem 1 %32
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    Pergunte ao FixBot
    Comentar
  4. Samsung SPEX SCH-R210 antenna Replacement, Antenna: passo 4, imagem 1 %32 Samsung SPEX SCH-R210 antenna Replacement, Antenna: passo 4, imagem 2 %32
    • After removing the battery, unscrew the 4 3/16" screws on the black plastic cover with the Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Samsung SPEX SCH-R210 antenna Replacement: passo 5, imagem 1 %32 Samsung SPEX SCH-R210 antenna Replacement: passo 5, imagem 2 %32
    • Remove the headphone cover from the left side and the volume cover from the right side of the phone.
    Pergunte ao FixBot
    Comentar
  6. Samsung SPEX SCH-R210 antenna Replacement: passo 6, imagem 1 %32
    • Remove the black plastic cover from the back of the phone. This may take a little effort to remove.
    Pergunte ao FixBot
    Comentar
  7. Samsung SPEX SCH-R210 antenna Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • The antenna is located on the opposite side of the black plastic cover. Use the tweezers to remove the antenna.
    Pergunte ao FixBot
    Comentar
  8. Samsung SPEX SCH-R210 antenna Replacement: passo 8, imagem 1 %32
    • The gray rubber antenna cover will need to come out as well. Use the tweezers to remove the gray cover.
    Pergunte ao FixBot
    Comentar
  9. Samsung SPEX SCH-R210 antenna Replacement: passo 9, imagem 1 %32
    • Replace with a new antenna.
    Pergunte ao FixBot
    Comentar
Conclusão
Susan
Membro desde: 07/11/13
331 Reputação
Autoria de 3 guias
Equipe
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Membro de WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 539
