Ir para o conteúdo principal
Samsung SPEX SCH-R210 Keypad Replacement
O que você precisa
  1. Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: passo 1, imagem 1 %32 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: passo 1, imagem 2 %32 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: passo 1, imagem 3 %32
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    Pergunte ao FixBot
    Comentar
  2. Samsung SPEX SCH-R210 Keypad Replacement, Battery: passo 2, imagem 1 %32
    • Locate the access notch at the end of the battery compartment.
    Pergunte ao FixBot
    Comentar
  3. Samsung SPEX SCH-R210 Keypad Replacement: passo 3, imagem 1 %32
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    Pergunte ao FixBot
    Comentar
  4. Samsung SPEX SCH-R210 Keypad Replacement, Keypad: passo 4, imagem 1 %32 Samsung SPEX SCH-R210 Keypad Replacement, Keypad: passo 4, imagem 2 %32
    • Remove the four 4.8 mm screws from the midframe using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Samsung SPEX SCH-R210 Keypad Replacement: passo 5, imagem 1 %32
    • Remove the headphone cover from the left side of the midframe.
    Pergunte ao FixBot
    Comentar
  6. Samsung SPEX SCH-R210 Keypad Replacement: passo 6, imagem 1 %32
    • Remove the volume cover from the right side of the midframe.
    Pergunte ao FixBot
    Comentar
  7. Samsung SPEX SCH-R210 Keypad Replacement: passo 7, imagem 1 %32
    • Use your hands to separate the midframe from the rest of the phone.
    • This may take a little effort to remove.
    Pergunte ao FixBot
    Comentar
  8. Samsung SPEX SCH-R210 Keypad Replacement: passo 8, imagem 1 %32
    • Use a 1.5 mm hex screwdriver to remove the three 2.4 mm screws around the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Samsung SPEX SCH-R210 Keypad Replacement: passo 9, imagem 1 %32
    • Lift the metal plate off of the motherboard and set it aside.
    Pergunte ao FixBot
    Comentar
  10. Samsung SPEX SCH-R210 Keypad Replacement: passo 10, imagem 1 %32 Samsung SPEX SCH-R210 Keypad Replacement: passo 10, imagem 2 %32
    • Push on the white plastic tabs and the keypad at the same time to remove the motherboard.
    Pergunte ao FixBot
    Comentar
  11. Samsung SPEX SCH-R210 Keypad Replacement: passo 11, imagem 1 %32 Samsung SPEX SCH-R210 Keypad Replacement: passo 11, imagem 2 %32
    • Turn the phone over to its front side.
    • Apply pressure on the keypad.
    • The keypad will come out easily.
    Pergunte ao FixBot
    Comentar
Conclusão
Susan
Membro desde: 07/11/13
331 Reputação
Autoria de 3 guias
Equipe
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Membro de WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 27
Ao todo: 623
