Ir para o conteúdo principal
Samsung SGH-X495 Screen Replacement
O que você precisa
  1. Samsung SGH-X495 Screen Replacement, Backplate: passo 1, imagem 1 %32
    • Remove the 4 (4.7mm) philips head screws.
    Pergunte ao FixBot
    Comentar
  2. Samsung SGH-X495 Screen Replacement: passo 2, imagem 1 %32
    • Unplug the rubber charger outlet cover.
    Pergunte ao FixBot
    Comentar
  3. Samsung SGH-X495 Screen Replacement: passo 3, imagem 1 %32
    • Unplug the rubber headset jack cover.
    Pergunte ao FixBot
    Comentar
  4. Samsung SGH-X495 Screen Replacement: passo 4, imagem 1 %32 Samsung SGH-X495 Screen Replacement: passo 4, imagem 2 %32
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
    Pergunte ao FixBot
    Comentar
  5. Samsung SGH-X495 Screen Replacement: passo 5, imagem 1 %32 Samsung SGH-X495 Screen Replacement: passo 5, imagem 2 %32
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
    Pergunte ao FixBot
    Comentar
  6. Samsung SGH-X495 Screen Replacement, Face Plate: passo 6, imagem 1 %32
    • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
    Pergunte ao FixBot
    Comentar
  7. Samsung SGH-X495 Screen Replacement: passo 7, imagem 1 %32
    • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
    Pergunte ao FixBot
    Comentar
  8. Samsung SGH-X495 Screen Replacement: passo 8, imagem 1 %32 Samsung SGH-X495 Screen Replacement: passo 8, imagem 2 %32
    • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
    • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
    Pergunte ao FixBot
    Comentar
  9. Samsung SGH-X495 Screen Replacement: passo 9, imagem 1 %32 Samsung SGH-X495 Screen Replacement: passo 9, imagem 2 %32
    • Continue down each side toward the bottom with your pry tool.
    • Note: It may help to use multiple pry tools to help hold it open.
    • Second photo: location of the tabs.
    Pergunte ao FixBot
    Comentar
  10. Samsung SGH-X495 Screen Replacement: passo 10, imagem 1 %32 Samsung SGH-X495 Screen Replacement: passo 10, imagem 2 %32
    • With 8 tabs released, the face plate is nearly free.
    • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • Note: A strip of double sided tape holds the faceplate, so expect some resistance
    Pergunte ao FixBot
    Comentar
  11. Samsung SGH-X495 Screen Replacement, Screen: passo 11, imagem 1 %32
    • Use an opening tool to gently lift the ribbon wire connection to the screen.
    Pergunte ao FixBot
    Comentar
  12. Samsung SGH-X495 Screen Replacement: passo 12, imagem 1 %32
    • Pull back the protective sticker to open access through the phones joint.
    Pergunte ao FixBot
    Comentar
  13. Samsung SGH-X495 Screen Replacement: passo 13, imagem 1 %32
    • Carefully feed ribbon wire through the phones joint.
    Pergunte ao FixBot
    Comentar
Conclusão
Matthew Hove
Membro desde: 01/05/11
1.031 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 3-40, Regan Winter 2011 Membro de Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 1,663
