Ir para o conteúdo principal
Samsung SCV-VLUUST50 Flash Bulb Replacement
O que você precisa
    1. Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: passo 1, imagem 1 %32 Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: passo 1, imagem 2 %32 Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: passo 1, imagem 3 %32
      • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
      • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
      Pergunte ao FixBot
      Comentar
    2. Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 2, imagem 1 %32 Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 2, imagem 2 %32 Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 2, imagem 3 %32
      • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
      • Remove the corner panel by applying pressure away from the shutter button.
      • The memory card cover will come off with the corner panel.
      • Remove the top panel by applying gentle pressure away from the shutter button.
      Pergunte ao FixBot
      Comentar
    3. Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 3, imagem 1 %32
      • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
      Pergunte ao FixBot
      Comentar
    4. Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 4, imagem 1 %32 Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 4, imagem 2 %32
      • Remove the front and back covers by pulling them straight apart.
      Pergunte ao FixBot
      Comentar
    1. Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: passo 5, imagem 1 %32 Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: passo 5, imagem 2 %32
      • Remove the screw securing the shutter button to the camera frame.
      • Lift the shutter button to remove it.
      Pergunte ao FixBot
      Comentar
    2. Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 6, imagem 1 %32 Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 6, imagem 2 %32
      • Remove the screws from the circuitry with a Phillips #000 driver.
      • Remove the screw connecting the flash housing to the camera frame with the same driver.
      Pergunte ao FixBot
      Comentar
    3. Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 7, imagem 1 %32 Samsung SCV-VLUUST50 Flash Bulb Replacement: passo 7, imagem 2 %32
      • Pull the flash housing away from the camera frame.
      • Cut the wires connecting the flash module to the circuitry.
      • Connect the new flash module to the circuitry with a soldering iron and electrical solder.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 483
