Ir para o conteúdo principal
Samsung Rogue Front Function Keys Replacement
O que você precisa
  1. Samsung Rogue Front Function Keys Replacement, Battery: passo 1, imagem 1 %32 Samsung Rogue Front Function Keys Replacement, Battery: passo 1, imagem 2 %32
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
    Pergunte ao FixBot
    Comentar
  2. Samsung Rogue Front Function Keys Replacement: passo 2, imagem 1 %32 Samsung Rogue Front Function Keys Replacement: passo 2, imagem 2 %32
    • You can now remove the battery by prying it up with your finger.
    Pergunte ao FixBot
    Comentar
  3. Samsung Rogue Front Function Keys Replacement, Motherboard: passo 3, imagem 1 %32
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
    Pergunte ao FixBot
    Comentar
  4. Samsung Rogue Front Function Keys Replacement: passo 4, imagem 1 %32
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
    Pergunte ao FixBot
    Comentar
  5. Samsung Rogue Front Function Keys Replacement: passo 5, imagem 1 %32 Samsung Rogue Front Function Keys Replacement: passo 5, imagem 2 %32 Samsung Rogue Front Function Keys Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
    Pergunte ao FixBot
    Comentar
  6. Samsung Rogue Front Function Keys Replacement: passo 6, imagem 1 %32
    • Remove the two 3.45 mm Philips screws below the white sticker.
    Pergunte ao FixBot
    Comentar
  7. Samsung Rogue Front Function Keys Replacement: passo 7, imagem 1 %32 Samsung Rogue Front Function Keys Replacement: passo 7, imagem 2 %32
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
    Pergunte ao FixBot
    Comentar
  8. Samsung Rogue Front Function Keys Replacement: passo 8, imagem 1 %32 Samsung Rogue Front Function Keys Replacement: passo 8, imagem 2 %32
    • Use a plastic opening tool to disconnect the film from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Samsung Rogue Front Function Keys Replacement, Front Function Keys: passo 9, imagem 1 %32
    • Remove the eight 1.7mm Philips screws above the keyboard.
    Pergunte ao FixBot
    Comentar
  10. Samsung Rogue Front Function Keys Replacement: passo 10, imagem 1 %32
    • Carefully remove keyboard frame from the sliding mechanisms underneath.
    Pergunte ao FixBot
    Comentar
  11. Samsung Rogue Front Function Keys Replacement: passo 11, imagem 1 %32
    • Remove the five 3.0mm Philips screws around the outside of the sliding mechanisms.
    Pergunte ao FixBot
    Comentar
  12. Samsung Rogue Front Function Keys Replacement: passo 12, imagem 1 %32 Samsung Rogue Front Function Keys Replacement: passo 12, imagem 2 %32 Samsung Rogue Front Function Keys Replacement: passo 12, imagem 3 %32
    • Use a plastic opening tool to pry off the upper slide plate.
    • Be careful of the film of wires when taking off the upper slide plate.
    Pergunte ao FixBot
    Comentar
  13. Samsung Rogue Front Function Keys Replacement: passo 13, imagem 1 %32 Samsung Rogue Front Function Keys Replacement: passo 13, imagem 2 %32 Samsung Rogue Front Function Keys Replacement: passo 13, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to open the two black gates by putting them in the "up" position.
    • With the same tweezers, carefully pull out the orange strips from the two specified gates.
    Pergunte ao FixBot
    Comentar
  14. Samsung Rogue Front Function Keys Replacement: passo 14, imagem 1 %32 Samsung Rogue Front Function Keys Replacement: passo 14, imagem 2 %32 Samsung Rogue Front Function Keys Replacement: passo 14, imagem 3 %32
    • Using tweezers, gently remove the bottom orange strip from the device.
    • At this point you can easily lift out the rubber function key pad as well.
    Pergunte ao FixBot
    Comentar
  15. Samsung Rogue Front Function Keys Replacement: passo 15, imagem 1 %32 Samsung Rogue Front Function Keys Replacement: passo 15, imagem 2 %32 Samsung Rogue Front Function Keys Replacement: passo 15, imagem 3 %32
    • There are two ways you can take out the front function keys:
    • 1) Use a plastic phone opening tool to pry out the piece from the front of the phone.
    • 2) Simply pop out the piece from the inside by pushing on its tabs.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 7-32, Maness Spring 2012 Membro de Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 706
