Ir para o conteúdo principal
Samsung Refrigerator Ice Bucket (Ice Tray) Replacement
O que você precisa
  1. Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Open the refrigerator doors: passo 1, imagem 1 %32 Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Open the refrigerator doors: passo 1, imagem 2 %32
    • Open both French doors for the refrigerator compartment.
    Pergunte ao FixBot
  2. Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Remove the ice bucket: passo 2, imagem 1 %32
    • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
    Pergunte ao FixBot
  3. Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Remove the ice bucket: passo 3, imagem 1 %32 Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Remove the ice bucket: passo 3, imagem 2 %32 Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Remove the ice bucket: passo 3, imagem 3 %32
    Pergunte ao FixBot
  4. Samsung Refrigerator Ice Bucket (Ice Tray) Replacement, Check the ice bucket condition: passo 4, imagem 1 %32
    • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
    • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
    Pergunte ao FixBot
Conclusão
Repair didn’t go as planned? Ask our Answers Community for help.
Uma outra pessoa concluiu este guia.
Matt Zieminski
Membro desde: 02/23/15
49.821 Reputação
Autoria de 28 guias
Equipe
testy Membro de testy
Business
1 Membro
Autoria de 164 guias
4Comentários do guia
Ice dispenser cracked.. Samsung french door refrigerator...can it be fixed
Irene Motha - Responder Compartilhar
Used Testor’s non toxic model cement after cleaning the crack with alcohol.
Mike Remote - Responder Compartilhar
Can't get the ice bucket to line up with the auger b
Gear
Lew Pirozzi - Responder Compartilhar
Can't get the ice bucket auger gear to line up with the motor arm.wont close.
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 77
Últimos 30 dias: 372
Ao todo: 12,732
