Ir para o conteúdo principal
Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement
O que você precisa
  1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Open the freezer drawer: passo 2, imagem 1 %32
    • Slide the freezer drawer fully open.
  3. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer bins: passo 3, imagem 1 %32
    • Lift and remove all the freezer bins from the drawer.
    • You should be left with a freezer door attached by two rails.
  4. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: passo 4, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: passo 4, imagem 2 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: passo 4, imagem 3 %32
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 5, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 5, imagem 2 %32
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  6. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer compartment evaporator cover: passo 6, imagem 1 %32
    • Remove the screws securing the freezer evaporator cover.
  7. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 7, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 7, imagem 2 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 7, imagem 3 %32
    • Don't try to fully remove the evaporator cover yet, as it's connected to the refrigerator by a few wires in the top right corner.
    • Use your hands to lift the bottom edge of the evaporator cover up to release the lower plastic tabs.
    • Swing the evaporator cover upwards to access the connected wires behind it.
  8. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 8, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 8, imagem 2 %32
    • Use your fingers to squeeze and disconnect the fan cable connector from the back wall of the freezer.
  9. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 9, imagem 1 %32
    • Remove the evaporator cover.
  10. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: passo 10, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: passo 10, imagem 2 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: passo 10, imagem 3 %32
    • Guide the fan cable from the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  11. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 11, imagem 1 %32
    • Remove the screws securing the back panel to the evaporator cover.
  12. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 12, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 12, imagem 2 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 12, imagem 3 %32
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  13. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 13, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 13, imagem 2 %32 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 13, imagem 3 %32
    • Lift and separate the back panel from the evaporator cover.
  14. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 14, imagem 1 %32
    • Remove the screws securing the fan to the evaporator cover.
  15. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 15, imagem 1 %32
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
Conclusão
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Membro desde: 04/14/15
15.945 Reputação
Autoria de 89 guias
Equipe
Team Vulcan Membro de Team Vulcan
Staff
6 Membros
Autoria de 212 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 34
Últimos 30 dias: 234
Ao todo: 6,362
