Ir para o conteúdo principal
Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement
O que você precisa
  1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Unplug your refrigerator: passo 1, imagem 1 %32
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: passo 2, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: passo 2, imagem 2 %32
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: passo 3, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: passo 3, imagem 2 %32
    • Remove all the loose shelves and bins from the refrigerator compartment.
    • The bottom shelf is clipped in place. Follow the next step to remove it.
  4. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 4, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 4, imagem 2 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 4, imagem 3 %32
    • Two stiff plastic tabs (one on each side) secure the bottom shelf in place.
    • Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
    • If the shelf doesn't unclip, you can try using a flathead screwdriver to press each clip in.
    • Remove the bottom shelf.
  5. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: passo 5, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: passo 5, imagem 2 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: passo 5, imagem 3 %32
    • Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
  6. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 6, imagem 1 %32
    • Remove the screws securing the evaporator cover.
  7. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 7, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 7, imagem 2 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 7, imagem 3 %32
    • Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
    • Don't try to fully remove the cover in this step, as it's connected by several wires.
  8. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 8, imagem 1 %32
    • Squeeze and disconnect all the wire connectors connecting the evaporator cover to the refrigerator.
  9. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 9, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 9, imagem 2 %32
    • Pull the evaporator cover towards you and remove it.
  10. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the evaporator fan: passo 10, imagem 1 %32
    • Remove the screws securing the fan bracket to the evaporator cover.
  11. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 11, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 11, imagem 2 %32
    • Remove the fan cable from the cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  12. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 12, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 12, imagem 2 %32
    • Lift the loose edge of the fan bracket up.
  13. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 13, imagem 1 %32 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 13, imagem 2 %32
    • The fan is pressure-fit in place with some foam insulation.
    • Use your fingers to press the fan out of its recess.
  14. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: passo 14, imagem 1 %32
    • Remove the fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down, towards the evaporator cover.
Conclusão
Repair didn’t go as planned? Ask our Answers Community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 88 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 35
Autoria de 603 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 44
Últimos 30 dias: 228
Duração total: 1,528
