Introdução
Wi-Fi card replacement may be done when the Wi-Fi card is suspected to be damaged. Take a look at the troubleshooting page before starting this guide to review the typical issues.
O que você precisa
Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
Carefully remove the back panel..
Remove the eight 5mm Phillips #0 screws using a Phillips #0 driver.
Also remove the three 5mm Phillips #0 using a Phillips #0 driver.
