Ir para o conteúdo principal
Samsung RC512 Screen Replacement
O que você precisa
  1. Samsung RC512 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down.
  2. Samsung RC512 Screen Replacement: passo 2, imagem 1 %32 Samsung RC512 Screen Replacement: passo 2, imagem 2 %32
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Screen Replacement, Screen: passo 3, imagem 1 %32 Samsung RC512 Screen Replacement, Screen: passo 3, imagem 2 %32 Samsung RC512 Screen Replacement, Screen: passo 3, imagem 3 %32
    • The Laptop should be off before removing the battery.
  4. Samsung RC512 Screen Replacement: passo 4, imagem 1 %32 Samsung RC512 Screen Replacement: passo 4, imagem 2 %32 Samsung RC512 Screen Replacement: passo 4, imagem 3 %32
    • Remove the gray covers with tweezers to expose the 4mm screws.
    • Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
  5. Samsung RC512 Screen Replacement: passo 5, imagem 1 %32 Samsung RC512 Screen Replacement: passo 5, imagem 2 %32
    • Insert the blue plastic opening tool into the bezel and rear housing of the screen.
    • Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Work your way around the sides carefully and continue this to the bottom.
    • You may use your fingers to help remove the cover.
  6. Samsung RC512 Screen Replacement: passo 6, imagem 1 %32 Samsung RC512 Screen Replacement: passo 6, imagem 2 %32
    • With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
    • As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
  7. Samsung RC512 Screen Replacement: passo 7, imagem 1 %32 Samsung RC512 Screen Replacement: passo 7, imagem 2 %32 Samsung RC512 Screen Replacement: passo 7, imagem 3 %32
    • Gently lay the LCD onto the keyboard.
    • Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together.
    • Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Grasp the video connector at its base and pull it away from the LCD screen.
    • The only thing holding the screen will be the clear tape causing it to come out easily.
Conclusão
Uma outra pessoa concluiu este guia.
jando
Membro desde: 09/15/16
896 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 18-2, Blackwell Fall 2016 Membro de USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 696
