Ir para o conteúdo principal
Samsung PL20 LCD Replacement
O que você precisa
  1. Samsung PL20 LCD Replacement, LCD: passo 1, imagem 1 %32 Samsung PL20 LCD Replacement, LCD: passo 1, imagem 2 %32 Samsung PL20 LCD Replacement, LCD: passo 1, imagem 3 %32
    • Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
    • Remove the battery and the memory card from the device, if so equipped.
    • Remove the two screws on the left side.
  2. Samsung PL20 LCD Replacement: passo 2, imagem 1 %32 Samsung PL20 LCD Replacement: passo 2, imagem 2 %32 Samsung PL20 LCD Replacement: passo 2, imagem 3 %32
    • Remove one screw from the bottom
    • Remove the two screws on the right side.
    • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
  3. Samsung PL20 LCD Replacement: passo 3, imagem 1 %32 Samsung PL20 LCD Replacement: passo 3, imagem 2 %32 Samsung PL20 LCD Replacement: passo 3, imagem 3 %32
    • Once the back of the case is removed, the LCD becomes immediately visible.
    • Remove the LCD from its holder to gain access to the connector.
    • Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
Conclusão
6 outras pessoas executaram este guia.
oldturkey03
Membro desde: 09/29/10
783.207 Reputação
Autoria de 119 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 33
Autoria de 549 guias
Um comentário
Great help! Screen replaced no problem. Thank you
EE61 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 40
Duração total: 3,513
