Ir para o conteúdo principal
Samsung NX300 CMOS Sensor Assembly Replacement
O que você precisa
    1. Samsung NX300 CMOS Sensor Assembly Replacement, Unscrew the Back Panel: passo 1, imagem 1 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Unscrew the Back Panel: passo 1, imagem 2 %32
      • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
      • On the NX300M model, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
      Pergunte ao FixBot
      Comentar
    2. Samsung NX300 CMOS Sensor Assembly Replacement, Remove the Input Port Screw: passo 2, imagem 1 %32
      • Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
      Pergunte ao FixBot
      Comentar
    3. Samsung NX300 CMOS Sensor Assembly Replacement, Open the Camera Casing: passo 3, imagem 1 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Open the Camera Casing: passo 3, imagem 2 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Open the Camera Casing: passo 3, imagem 3 %32
      • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
      Pergunte ao FixBot
      Comentar
    4. Samsung NX300 CMOS Sensor Assembly Replacement, Remove the Back Panel: passo 4, imagem 1 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Remove the Back Panel: passo 4, imagem 2 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Remove the Back Panel: passo 4, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
      • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
      Pergunte ao FixBot
      Comentar
    1. Samsung NX300 CMOS Sensor Assembly Replacement, Unscrew the Motherboard: passo 5, imagem 1 %32
      • Using a Phillips #00 precision screwdriver, remove the three 4mm screws holding the motherboard in place.
      Pergunte ao FixBot
      Comentar
    2. Samsung NX300 CMOS Sensor Assembly Replacement, Detach the Ribbons: passo 6, imagem 1 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Detach the Ribbons: passo 6, imagem 2 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Detach the Ribbons: passo 6, imagem 3 %32
      • Using tweezers or a plastic opening tool, release the locks on the ribbon receptors by flicking up the black bars on the holds. Pull the five ribbons away from the motherboard (one hidden from view). This will free the motherboard completely from the device.
      Pergunte ao FixBot
      Comentar
    3. Samsung NX300 CMOS Sensor Assembly Replacement: passo 7, imagem 1 %32
      • The motherboard is now free. Pull the motherboard up and slightly away from the input compartment; it will lift out easily.
      Pergunte ao FixBot
      Comentar
    1. Samsung NX300 CMOS Sensor Assembly Replacement, Remove the Top Panel: passo 8, imagem 1 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Remove the Top Panel: passo 8, imagem 2 %32
      • Using a Phillips #00 screwdriver, remove the last 4mm screw attaching the top panel to the rest of the camera.
      • With the assistance of plastic opening tools, carefully unsnap the top panel, which contains the power switch, out of place.
      Pergunte ao FixBot
      Comentar
    2. Samsung NX300 CMOS Sensor Assembly Replacement, Remove the Sensor Assembly: passo 9, imagem 1 %32
      • Using a 1.5mm HEX screwdriver, remove the three 5mm black screws located on the extensions of the metal housing assembly.
      Pergunte ao FixBot
      Comentar
    3. Samsung NX300 CMOS Sensor Assembly Replacement, Pull the Data Ribbon: passo 10, imagem 1 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Pull the Data Ribbon: passo 10, imagem 2 %32
      • With the assistance of tweezers, pull out the last data ribbon connecting the sensor to the sound board. This ribbon must be pulled away from the board that houses the sound speaker.
      Pergunte ao FixBot
      Comentar
    4. Samsung NX300 CMOS Sensor Assembly Replacement, Free the CMOS Sensor: passo 11, imagem 1 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Free the CMOS Sensor: passo 11, imagem 2 %32 Samsung NX300 CMOS Sensor Assembly Replacement, Free the CMOS Sensor: passo 11, imagem 3 %32
      • The entire CMOS sensor assembly is now free.
      • To replace the assembly's low-pass filter, infrared-absorption glass and/or the piezoelectric element only, use a Phillips #00 screwdriver to remove the two 4mm screws on the top and bottom sides of the sensor assembly.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Andres Perez
Membro desde: 01/21/15
1.023 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 9-6, Blackwell Winter 2015 Membro de USF Tampa, Team 9-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G6
4 Membros
Autoria de 12 guias
1Comentário do guia
Where can I find a replacement cmos though?
Nibbles McMeow - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 45
Ao todo: 7,248
