Ir para o conteúdo principal
Samsung NX Mini Button Panel Replacement
O que você precisa
    1. Samsung NX Mini Button Panel Replacement, Battery: passo 1, imagem 1 %32 Samsung NX Mini Button Panel Replacement, Battery: passo 1, imagem 2 %32 Samsung NX Mini Button Panel Replacement, Battery: passo 1, imagem 3 %32
      • Orient the camera so the button panel and LCD are facing you.
      • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
      Pergunte ao FixBot
      Comentar
    2. Samsung NX Mini Button Panel Replacement: passo 2, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 2, imagem 2 %32
      • Push the blue trapdoor to the left to release the battery, and remove the battery.
      • There is no battery shown in this photo.
      Pergunte ao FixBot
      Comentar
    1. Samsung NX Mini Button Panel Replacement, Front Case: passo 3, imagem 1 %32
      • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
      Pergunte ao FixBot
      Comentar
    2. Samsung NX Mini Button Panel Replacement: passo 4, imagem 1 %32
      • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
      Pergunte ao FixBot
      Comentar
    3. Samsung NX Mini Button Panel Replacement: passo 5, imagem 1 %32
      • Remove the four 5 mm Phillips #00 screws from the lens assembly.
      Pergunte ao FixBot
      Comentar
    4. Samsung NX Mini Button Panel Replacement: passo 6, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Remove the metal lens mount by hand or with tweezers.
      • Be careful not to touch the sensor in the center of the lens assembly.
      Pergunte ao FixBot
      Comentar
    5. Samsung NX Mini Button Panel Replacement: passo 7, imagem 1 %32
      • Use tweezers to remove the inner metal ring.
      Pergunte ao FixBot
      Comentar
    6. Samsung NX Mini Button Panel Replacement: passo 8, imagem 1 %32
      • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
      Pergunte ao FixBot
      Comentar
    7. Samsung NX Mini Button Panel Replacement: passo 9, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 9, imagem 2 %32
      • Use your hands to slowly pull the front casing away from the camera.
      • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
      Pergunte ao FixBot
      Comentar
    1. Samsung NX Mini Button Panel Replacement, Sensor: passo 10, imagem 1 %32 Samsung NX Mini Button Panel Replacement, Sensor: passo 10, imagem 2 %32 Samsung NX Mini Button Panel Replacement, Sensor: passo 10, imagem 3 %32
      • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
      • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
      • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
      • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
      Pergunte ao FixBot
      Comentar
    2. Samsung NX Mini Button Panel Replacement: passo 11, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 11, imagem 2 %32
      • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
      Pergunte ao FixBot
      Comentar
    3. Samsung NX Mini Button Panel Replacement: passo 12, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 12, imagem 2 %32 Samsung NX Mini Button Panel Replacement: passo 12, imagem 3 %32
      • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
      • Remove the battery compartment.
      Pergunte ao FixBot
      Comentar
    4. Samsung NX Mini Button Panel Replacement: passo 13, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 13, imagem 2 %32
      • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
      Pergunte ao FixBot
      Comentar
    5. Samsung NX Mini Button Panel Replacement: passo 14, imagem 1 %32
      • Gently remove the sensor mount from the camera case.
      Pergunte ao FixBot
      Comentar
    1. Samsung NX Mini Button Panel Replacement, Motherboard: passo 15, imagem 1 %32 Samsung NX Mini Button Panel Replacement, Motherboard: passo 15, imagem 2 %32
      • Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
      Pergunte ao FixBot
      Comentar
    2. Samsung NX Mini Button Panel Replacement: passo 16, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 16, imagem 2 %32
      • Use tweezers to disconnect the wifi antenna from the motherboard.
      Pergunte ao FixBot
      Comentar
    3. Samsung NX Mini Button Panel Replacement: passo 17, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 17, imagem 2 %32 Samsung NX Mini Button Panel Replacement: passo 17, imagem 3 %32
      • Use a spudger to disconnect the LCD ribbon cable by prying it straight up from the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Samsung NX Mini Button Panel Replacement: passo 18, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 18, imagem 2 %32 Samsung NX Mini Button Panel Replacement: passo 18, imagem 3 %32
      • Use a spudger to unlock the topmost ZIF connector by flipping open the black flap.
      Pergunte ao FixBot
      Comentar
    5. Samsung NX Mini Button Panel Replacement: passo 19, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 19, imagem 2 %32
      • Insert the pointed end of a spudger into the hole in the middle of the ribbon cable.
      • Gently pull the spudger back to slide the ribbon cable out of its connector.
      Pergunte ao FixBot
      Comentar
    6. Samsung NX Mini Button Panel Replacement: passo 20, imagem 1 %32 Samsung NX Mini Button Panel Replacement: passo 20, imagem 2 %32 Samsung NX Mini Button Panel Replacement: passo 20, imagem 3 %32
      • Disconnect the blue ribbon cable from the motherboard.
      • Insert the pointed end of a spudger into the hole in the top of the ribbon.
      • Gently pull the ribbon from the connector.
      Pergunte ao FixBot
      Comentar
    7. Samsung NX Mini Button Panel Replacement: passo 21, imagem 1 %32
      • Remove the motherboard from the camera.
      Pergunte ao FixBot
      Comentar
    1. Samsung NX Mini Button Panel Replacement, Button Panel: passo 22, imagem 1 %32
      • Remove the three 4 mm Phillips #00 screws securing the button panel to the camera case.
      Pergunte ao FixBot
      Comentar
    2. Samsung NX Mini Button Panel Replacement: passo 23, imagem 1 %32
      • Use tweezers to lift the button panel cover away from the case.
      Pergunte ao FixBot
      Comentar
Conclusão
Kelsea Weber
Membro desde: 11/12/15
21.461 Reputação
Autoria de 32 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 843
