Ir para o conteúdo principal
Samsung NP-QX411L Screen Replacement
O que você precisa
  1. Samsung NP-QX411L Screen Replacement, Optical Drive: passo 1, imagem 1 %32 Samsung NP-QX411L Screen Replacement, Optical Drive: passo 1, imagem 2 %32
    • Flip the laptop over.
    • Remove the 6 mm screw with the Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Samsung NP-QX411L Screen Replacement: passo 2, imagem 1 %32
    • Slide out the optical drive to remove it.
    Pergunte ao FixBot
    Comentar
  3. Samsung NP-QX411L Screen Replacement, Hard Drive: passo 3, imagem 1 %32 Samsung NP-QX411L Screen Replacement, Hard Drive: passo 3, imagem 2 %32
    • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
    • Flip the laptop.
    • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
    Pergunte ao FixBot
    Comentar
  4. Samsung NP-QX411L Screen Replacement: passo 4, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 4, imagem 2 %32
    • Gently wedge the spudger under the square panel.
    • Run the spudger under the edges of the square panel to loosen it.
    • Remove the panel.
    Pergunte ao FixBot
    Comentar
  5. Samsung NP-QX411L Screen Replacement: passo 5, imagem 1 %32
    • Remove the hard drive slowly because it is still connected to a wire.
    • Pull up on the rubber flap or use the spudger to lift the hard drive.
    Pergunte ao FixBot
    Comentar
  6. Samsung NP-QX411L Screen Replacement: passo 6, imagem 1 %32
    • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
    Pergunte ao FixBot
    Comentar
  7. Samsung NP-QX411L Screen Replacement, Hinges: passo 7, imagem 1 %32 Samsung NP-QX411L Screen Replacement, Hinges: passo 7, imagem 2 %32
    • Disconnect the wire from the motherboard by pulling up and away from the laptop.
    Pergunte ao FixBot
    Comentar
  8. Samsung NP-QX411L Screen Replacement: passo 8, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the top two rubber stoppers using precision tweezers.
    Pergunte ao FixBot
    Comentar
  9. Samsung NP-QX411L Screen Replacement: passo 9, imagem 1 %32
    • Unscrew nine 6 mm screws on the cover using a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Samsung NP-QX411L Screen Replacement: passo 10, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 10, imagem 2 %32 Samsung NP-QX411L Screen Replacement: passo 10, imagem 3 %32
    • Wedge the spudger under the cover to gently pry it up.
    Pergunte ao FixBot
    Comentar
  11. Samsung NP-QX411L Screen Replacement: passo 11, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 11, imagem 2 %32 Samsung NP-QX411L Screen Replacement: passo 11, imagem 3 %32
    • Disconnect the wire by carefully using the plastic opening tool to pry the connector away from the motherboard.
    Pergunte ao FixBot
    Comentar
  12. Samsung NP-QX411L Screen Replacement: passo 12, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 12, imagem 2 %32 Samsung NP-QX411L Screen Replacement: passo 12, imagem 3 %32
    • Use precision tweezers to pop the antenna wires off of the WiFi card.
    Pergunte ao FixBot
    Comentar
  13. Samsung NP-QX411L Screen Replacement: passo 13, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 13, imagem 2 %32 Samsung NP-QX411L Screen Replacement: passo 13, imagem 3 %32
    • Open the laptop slightly.
    • Holding the laptop open, remove three 4 mm screws from each hinge (6 total) using a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  14. Samsung NP-QX411L Screen Replacement: passo 14, imagem 1 %32
    • Hold hinges in place with your thumb and slide the laptop away from the screen.
    Pergunte ao FixBot
    Comentar
  15. Samsung NP-QX411L Screen Replacement: passo 15, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 15, imagem 2 %32
    • Remove the 4 rubber stoppers with the precision tweezers.
    Pergunte ao FixBot
    Comentar
  16. Samsung NP-QX411L Screen Replacement: passo 16, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 16, imagem 2 %32
    • Remove the four 4 mm screws with a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  17. Samsung NP-QX411L Screen Replacement: passo 17, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 17, imagem 2 %32
    • The metal spudger could scratch the screen.
    • Wedge the metal spudger underneath the cover and run it along the edges. Gently pry the cover up.
    Pergunte ao FixBot
    Comentar
  18. Samsung NP-QX411L Screen Replacement: passo 18, imagem 1 %32 Samsung NP-QX411L Screen Replacement: passo 18, imagem 2 %32
    • Remove the three 4 mm screws on each hinge with a Phillips #000 screwdriver. There should be a total of 6 screws to remove.
    Pergunte ao FixBot
    Comentar
  19. Samsung NP-QX411L Screen Replacement, Screen: passo 19, imagem 1 %32 Samsung NP-QX411L Screen Replacement, Screen: passo 19, imagem 2 %32
    • Remove the four 4 mm screws using Phillips #000 screwdriver.
    • Remove metal brackets.
    Pergunte ao FixBot
    Comentar
  20. Samsung NP-QX411L Screen Replacement: passo 20, imagem 1 %32
    • Use the small suction cup to lift the screen.
    • Disconnect the wire by pulling it away from the bottom of the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team S19-G3, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G3, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G3
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 1,428
