Ir para o conteúdo principal
Samsung NP-QX411L Battery Replacement
O que você precisa
  1. Samsung NP-QX411L Battery Replacement, Optical Drive: passo 1, imagem 1 %32 Samsung NP-QX411L Battery Replacement, Optical Drive: passo 1, imagem 2 %32
    • Flip the laptop over.
    • Remove the 6 mm screw with the Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Samsung NP-QX411L Battery Replacement: passo 2, imagem 1 %32
    • Slide out the optical drive to remove it.
    Pergunte ao FixBot
    Comentar
  3. Samsung NP-QX411L Battery Replacement, Hard Drive: passo 3, imagem 1 %32 Samsung NP-QX411L Battery Replacement, Hard Drive: passo 3, imagem 2 %32
    • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
    • Flip the laptop.
    • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
    Pergunte ao FixBot
    Comentar
  4. Samsung NP-QX411L Battery Replacement: passo 4, imagem 1 %32 Samsung NP-QX411L Battery Replacement: passo 4, imagem 2 %32
    • Gently wedge the spudger under the square panel.
    • Run the spudger under the edges of the square panel to loosen it.
    • Remove the panel.
    Pergunte ao FixBot
    Comentar
  5. Samsung NP-QX411L Battery Replacement: passo 5, imagem 1 %32
    • Remove the hard drive slowly because it is still connected to a wire.
    • Pull up on the rubber flap or use the spudger to lift the hard drive.
    Pergunte ao FixBot
    Comentar
  6. Samsung NP-QX411L Battery Replacement: passo 6, imagem 1 %32
    • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
    Pergunte ao FixBot
    Comentar
  7. Samsung NP-QX411L Battery Replacement, Battery: passo 7, imagem 1 %32
    • Use the Phillips #000 screwdriver to remove the 6 mm screw.
    Pergunte ao FixBot
    Comentar
  8. Samsung NP-QX411L Battery Replacement: passo 8, imagem 1 %32 Samsung NP-QX411L Battery Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the top two rubber stoppers by grasping them with the precision tweezers and pulling up.
    Pergunte ao FixBot
    Comentar
  9. Samsung NP-QX411L Battery Replacement: passo 9, imagem 1 %32
    • Remove nine 6mm cover screws using the Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Samsung NP-QX411L Battery Replacement: passo 10, imagem 1 %32 Samsung NP-QX411L Battery Replacement: passo 10, imagem 2 %32 Samsung NP-QX411L Battery Replacement: passo 10, imagem 3 %32
    • Wedge the spudger under the cover and run it along the edges.
    • Pry the cover up with the spudger to remove it.
    Pergunte ao FixBot
    Comentar
  11. Samsung NP-QX411L Battery Replacement: passo 11, imagem 1 %32 Samsung NP-QX411L Battery Replacement: passo 11, imagem 2 %32
    • Remove the four 3 mm screws using the Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  12. Samsung NP-QX411L Battery Replacement: passo 12, imagem 1 %32
    • A wire is still connecting the battery to the motherboard.
    • Lift and slide the battery out from under the three plastic prongs.
    Pergunte ao FixBot
    Comentar
  13. Samsung NP-QX411L Battery Replacement: passo 13, imagem 1 %32
    • Grab the wires and gently pull them away from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S19-G3, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G3, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G3
4 Membros
Autoria de 5 guias
1Comentário do guia
Pardon the interruption, but do you potentially have a tutorial on how to replace the keyboard on this laptop? I am having problems finding an acceptable-enough tutorial on how to do it, yet I need such a tutorial as the process seems quite daunting.
Thanks,
Random Person on the Internet
Anonymous Schmuck - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 43
Ao todo: 4,537
