Ir para o conteúdo principal
Samsung NP-130-JA01US RAM Replacement
O que você precisa
  1. Samsung NP-130-JA01US RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
    Pergunte ao FixBot
    Comentar
  2. Samsung NP-130-JA01US RAM Replacement: passo 2, imagem 1 %32 Samsung NP-130-JA01US RAM Replacement: passo 2, imagem 2 %32
    • Slide the left and right slider buttons fully away from each other.
    Pergunte ao FixBot
    Comentar
  3. Samsung NP-130-JA01US RAM Replacement: passo 3, imagem 1 %32
    • Pull the battery out of the computer.
    Pergunte ao FixBot
    Comentar
  4. Samsung NP-130-JA01US RAM Replacement, RAM: passo 4, imagem 1 %32 Samsung NP-130-JA01US RAM Replacement, RAM: passo 4, imagem 2 %32
    • Locate the "Memory" panel on the bottom right corner.
    • Use the Phillips 01 screwdriver to remove the screw.
    • The screw is a Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    Pergunte ao FixBot
    Comentar
  5. Samsung NP-130-JA01US RAM Replacement: passo 5, imagem 1 %32
    • With your hand, lift panel and remove it.
    Pergunte ao FixBot
    Comentar
  6. Samsung NP-130-JA01US RAM Replacement: passo 6, imagem 1 %32 Samsung NP-130-JA01US RAM Replacement: passo 6, imagem 2 %32
    • Slide metal prongs (marked in red squares) away from each other with your fingers.
    • The RAM chip will automatically lift up at an angle for easy ejection.
    Pergunte ao FixBot
    Comentar
  7. Samsung NP-130-JA01US RAM Replacement: passo 7, imagem 1 %32
    • With your hands, carefully slide the RAM chip out to remove.
    • The RAM chip is delicate, do not force it when removing it.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 9-6, Lacy Fall 2016 Membro de USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 23
Ao todo: 522
